Question about Garden
Cranks up runs for about a minute the shuts down
2 Suggested Answers
  • 352 Answers
SOURCE: Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
Posted on May 31, 2015
Runs good for 10 minutes and then shuts off after it cools off it restarts
It is either the cam sensor or the crank sensor both will set check engine light, and shut car down. If the light is on get it scanned Any auto parts store will do this for free! po340 is camshaft sensor, if car stops and starts in 10 to 20 minutes ( a bad crank sensor will cause this.
Oct 14, 2015 | Cars & Trucks
May 31, 2015 | Cars & Trucks
1994 ford ranger runs fine until i go to town then just shuts down but will crank over and fuel is getting to it
check ignition pick up its in the distributor. its responsible for spark in the plugs
Dec 04, 2012 | 1988 Ford Ranger
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
Shuts down
Check the fuel pump relay, or may involve a defective ign-mod or crank/cam sensor failing when hot.
Jul 23, 2009 | 2004 Chevrolet Impala
Electrical Problem?Runs great then shuts down,let it sit runs fin
Sounds like the ECM is bad. This is a common problem, when the ECM gets hot there is a solder joint that seperates, it makes contact again once it cools down
Jun 17, 2009 | 1998 Plymouth Grand Voyager
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
