Question about Sony Computers & Internet
Connecting Sony Vaio to Toshiba TV
My laptop is sony vaio and have got VGA connector which has got 3 pins at another end that will be connected to TV. When i am trying to press Fn+F7 i am unable to get any picture on my TV...My tv is not LCD and it is a normal color TV...
Please help me how to resolve this.
Thanks,
S
  • 242 Answers
SOURCE: IS Toshiba mk6006gah HARD DRIVE COMPATIBLE WITH SONY VAIO
I know someone that bought a toshiba mk6006gah for his sony vaio TR1 series, so i think it is. Just look at the harddisk the local shop took out for you. Somewhere on the disk is told wich size it is. You could also give me the typenumber of that disk. Then i could tell you the size for certain.
Posted on Mar 27, 2008
Pyrhyc
  • 2028 Answers
SOURCE: connecting PC to TV
Most tv's are not compatible in this matter. They were made to be a tv, and not a computer monitor. Some of the newer tv's are compatible. If they have a vga port then they are compatible, but may not support or have the resolution expected. The vga to s-video cables were designed mainly for the use of the newer computers with vga ports to older flat panel monitors with s-video ports, at the time that vga was first coming out. This cable is on the verge of obsolete. So, I don't believe that you're going to be able to hook the two together, and get the outcome you want.
Posted on Jul 26, 2008
SOURCE: sony vaio geforce driver
what is the wesite name to download my VAIO-VGN--FE41m laptop
Posted on Dec 15, 2008
  • 38 Answers
SOURCE: sony vaio stuck in presentation mode
Right click on your desktop, go to display and change your resolution to one that is more pleasing.
Posted on Mar 25, 2009
romsky79
  • 822 Answers
SOURCE: not able to connect to (sense) LCD projector
please open your bios and enable FN key. if features does not appear in BIOS check the software and utility and install it.
Posted on Jul 02, 2009
Where is the projector connection on vaio fit
Insert one end of the VGA cable into your Sony Vaio. This is located on the left side of your computer.
Turn off the Infocus projector before connecting the opposite end of the VGA cable into the projector. The VGA input slot is located in the back of the projector.
Turn on the projector and allow time for it warm up.
Change the video output source on your computer to display through the projector. Press the "Windows" button and then "LCD/CRT" button on your Vaio keyboard to change the display source. On a Sony Vaio, the "LCD/CRT" button is usually "F7."
5
Focus the projector to most effectively display content from your computer. You can manually focus the projector or press the "Auto focus" button on the top of the projector.
Oct 02, 2013 | Sony Computers & Internet
Connecting sony viao to panasonic viera
try connecting through HDMI port on your laptop or use a VGA to HDMI converter or Connect with Wifi
Jan 26, 2013 | Sony VAIO Notebook
My Sony VAIO VGN-AR290G laptop cannot view another external screen. Originally, I closed the laptop lid on my charger and cracked the screen. Now the screen just shows white. I connected VGA cable to...
Hummmm.... are you sure your cable is good? Can you try connecting with another cable?...
Check the cable CONNECTORS and be sure NO pins are pushed back into the molded body. All should pins should be quite 'flush' with the outer connector metal frame.
Does your display work if you connect your cable and monitor to another system?
Gee I'm trying to envision a LCD display and it's associated electronics AND your SVGA connector?... I mean I know they both process video, but they should be independent of each other?
I have a newer TOSHIBA that had a LCD so trashed it kept dumping junk from the display... So I cut the display hinges OFF and cut the supporting cables to it too... hoping for no shorts!
That system is still working GREAT ~ with a external monitor... and no Wi-Fi and sorry that does not really help you.
Anthony
Nov 13, 2017 | Sony VAIO VGN-AR290G PC Notebook
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
VGA out not working
Try connecting any VGA device. I.e a projector.
Dec 04, 2009 | Sony VAIO VGN-FS740/W Notebook
How do I connect my sony vaio vgn-fs920 to a tv?
As far as I know I need:
1) to purchase that VGA - S-Video Adapter ?
2) to purchase S-Video Cable itself ?
3) to purchase something like audio AV cables as well ?
Does anybody know where I can buy VGA - S-Video Cable (without Adapters) if it's possible and DO I NEED TO BUY AUDIO CABLE IF I'M GOING TO CONNECT THRU S-VIDEO?
May 14, 2009 | Sony VAIO VGN-FS920 Notebook
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Connecting a Toshiba lcd tv to a Sony Vaio VGC-LA3
you should have a (vga) tv-out socket usually blue with about 16 pins in it,if you have not which is unusual then refer to sony for the laptops specs and location of tv-out socket.
The Nvidia graphics card should have one I believe the Gforce go card is the one for your system unless upgraded and is advertised to support this function.
Jan 14, 2009 | Computers & Internet
SONY LAPTOP
u must have tv input connection in ur laptop for watching tv. if so then ok if not install a tv tuner card in your laptop
Oct 31, 2008 | Sony VAIO VGN-N130G/W Notebook
Connecting a sony Vaio vgn-fe570g laptop to a Samsung Monitor
There is an issue with the vga port on 2006 - 2007 sony vaio laptops. It doesn't push enough power to samsung lcds. There are all sorts of complicated solutions suggested by all sorts of people. Don't waste your time. Get yourself a connection cable with gold contacts and you'll be straight. It costs approx. $33.99. I got this one and it works fine (and I have a weak-*** TZ):
http://www.circuitcity.com/ssm/Nexxtech-VGA-SVGA-Monitor-Cable-6-N6VGASVGA/sem/rpsm/oid/192558/catOid/0/rpem/ccd/productDetail.do
May 22, 2008 | Sony VAIO VGN-FE870E/H Notebook
Computers & Internet Logo
154 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
