Question about Garden
I have a push lawnmore with a 6.5 horsepower Brigs and stratton verticle engine----is there a oil drain plug and a oil filter to change on this engine???
  • 299 Answers
You need to **** the oil out from the dip stick tube and no there is no filter
Posted on Sep 27, 2009
Where is the oil plug to change oil in a brigs& Stratton xts 50 lawn mower
On my old B and S motor, the drain plug was a square headed bolt in the middle of the front bottom of the engine.
Jan 28, 2018 | Garden
Where is the plug to change the oil?
Amy, if drain is not in the bottom of engine by blade, turn mower on it's side to drain oil to change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change your Briggs Stratton engine oil
Toro 6 5hp GTS Oil Change mpg
Mar 26, 2016 | Poulan Pro Pr550n22sh 22-Inch 140cc Briggs...
220.brigs and Stratton oil how much insump
A small qt bottle of SAE 30 wt oil, of ANY brand is fine for use in lawnmowers. The tolerances for the piston ring and cylinder are not so close to warrant more expensive synthetic blends. A simple std grade (cheapest) 30 wt is fine. It is a good practice to drain and refill your lawnmower engine before each cutting season, replace the air filter, and spark plug. Carburetors tend to foul so empty the gas tank at the end of each cutting season by letting the mower run out of gas... empty the float bowl, if it has a drain screw... this will keep varnish and gum from forming when you store it. Keep a spare cord on hand as they break when you least expect them to and when you need to use the mower. Hardware stores sell replacement cord, just cut to lengths as needed.
Oct 11, 2014 | Garden
HOW DO YOU CHANGE OIL ON A briggs and stratton diamond i/c 15.5hp vertical shaft ride on mower
find the drain plug on side of engine usually near oil filter take out drain plug drain oil out replace plug remove filter install new one fill oil in filler tube check with dipstick until level reaches safe on the dipstick done
Aug 25, 2014 | Briggs & Stratton Garden
18hp v twin brigs when it runs oil comes out of carb
you will see a tube coming from engine block to carb, pull it loose at carb just under the air intake or right behind breather filter. start engine and if oil blows out then its a blown head gasket.
Jun 21, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How to change oil
There is a drain plug located on the lower side of engine somewhere....it varies from model to model. Simply take out drain plug....drain oil in approved container......replace oil filter( if your model has one) with a new one....lubing the oil filter seal before installing....replacing drain plug....and adding the correct amount and type oil for your model engine. Always return used oil to a recycling center...auto part store usually provide this service.
Apr 01, 2014 | Briggs & Stratton Garden
How do you change the oil filter on a Hyundai Accent 1998/99?
Replace the oil filter after draining the old oil, and" BEFORE "adding new fresh oil, otherwise you'll be dump all that fresh oil, on the ground,while you "TRY to get the new filter installed.
Step 1 Remove drain plug,Drain oil into drain pan
Step 2 Remove oil filter
Step 3 Reinstall drain plug,qnce oil has drained.
Step 4 Fill new filter with oil,lube seal on filter.
Step 5 Install new filter, Add fresh oil to proper level.replace filler cap
Step 6 Run engine check for leaks.
Happy motoring!
May 23, 2008 | 1999 Hyundai Accent
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
