Question about Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite UT21506 lawn trimer
Pull cord spring needs to be rewound and reassembled
5 Suggested Answers
trippssmengi
  • 76 Answers
SOURCE: homelite mighty lawn trimmer vt26
Go to www.homelite.com then in the red area up top click on order parts, then click launch parts catalog, then scroll down and click agree and then you will need your model # then you will have a list of breakdowns that you can look at for your trimmer
Posted on Jan 05, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
emissionwiz
  • 76164 Answers
SOURCE: HOW CAN I OBTAIN A MAINTAINANCE MANUAL FOR A
Hello
In order to find a manual for you I will need the Model number of the trimmer, the Serial number doesn't cross over. You can however buy a generic Maintenance manual (covers 100's of Homelite models) at the web link below. Due to the age this is most likely all that will be available.
http://www.clymer.com/SearchResults.aspx?mn=Homelite&mid=120
Posted on May 07, 2011
vincob
  • 718 Answers
SOURCE: I need an address to
Go to psep.biz or jackssmallengines.com you will find all that you are looking for ! Godd Luck...
Posted on Aug 16, 2011
The pull cord stays out
You will need to buy a replacement housing that should come pre assembled so all you have to do is bolt it on
Jan 20, 2013 | Homelite Mighty Lite Lawn Trimmer
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
I need an address to purchase a fuel tank for my mighty lite 26cs . Model - UT21506 SN- ATK0712739
Aug 16, 2011 | Homelite Mighty Lite Lawn Trimmer
Pull cord stays out. Mechanic says I need new
check with home depot on parts for a homelite.
Oct 21, 2009 | Homelite Mighty Lite Lawn Trimmer
The Pull cord was jamming. I took it apart and
the rope and spring both have thier respective place in the housing for thier mountings they can be rewound by hand and reassembled with success,hint oppisite end of spring has a anchor point on the housing while one end is secured by a cup like screw mounting,to create the retracting force for retrival of the pull start rope its tricky if haven't done it before but you learn by trying Good luck Steve
Oct 01, 2009 | Homelite Mighty Lite Lawn Trimmer
After turning of engine. Starter pull cord stuck.
The recoil spring that rewinds the cord may have broken of pulled loose from its mooring.
Sep 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Trimmer Pull Start Cord
The part no. for the Spring and container is A98773A. You can Google the PN and find many sources. Expect to pay between $10.00 to $15.00. I like m-and-d.com If they have it in stock you will normally get it in 3 to 4 days.
Mar 25, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
943 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
