Question about Delta 22 - 547 12" Steel Knife Set for 22 - 540 Planer
Is there a part for a delta Planer 22.540 to connect to a dust collector?
  • 2,176 Answers
If there is you would find it at Dewaltservicenet.com and in the middle of the page under manual type in your model number for a schematic and owners manual for the tool.
Posted on Sep 27, 2009
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how to change blades in planer
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. Select the model number I looked at a type 2 and click on it on the next page find instruction manual on the left hand side and I did have to click 2 times before it brought it up but it is there I just read part of it. The manual is about 17 pages long but the page you need is 11. Let me know if there are any problems please and if I have helped in anyway would you please rate the response accordingly.
Posted on May 16, 2009
rowdy45176
  • 2176 Answers
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number on the next page click on the model on the left hand side and they when you get to the breakdown look for instructions manual, I generally have to click 2 times to open it up, after first click the box will go away just move your mouse and left click and it will come back and then click on it again. Go to page 11 of the instruction manual. If I have solved your problem would you please rate my response accordingly. Thank you
Posted on May 27, 2009
My sa380 15 inch auto planer dumps the shavings out the bottom even with the 4inch dust collector running this just started Is there a ajustment Ican make to correct this problem
Although the way you worded the questions suggests a wood shop problem, it is listed under vacuum cleaners.
I will speak to the planer being a wood shop machine.
I'd start by checking the dust collector for suction.
If it draws strongly, then perhaps you need to design a "chute" to cause the chips to go to the collector.
Perhaps a "rake" would be in order to move the chips neared the collector.
A rake nothing more than a broomstick with a flat board fastened to the end.
God bless your efforts.
Sep 08, 2016 | Vacuums
How do I replace the infeed dolor on a delta 22-260 planer
Most parts bought will come with the installation instructions
Delta 22 560 Type 1 Planer Parts
Cheers
Billy of Hayward
Sep 26, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Dewalt DW735 planer (chips inside the main housing)
Common problem. As long as the chip/dust doesn't impede the dust collection or interfere with anything else, it's normal, and to be expected.
Feb 04, 2018 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
I recently purchased a Delta 50-760 Dust Collector and was told I could convert the motor to 220 volt. I presently have a 220 volt saw and wanted to run them both on 220 so I looked at the book and it said...
I am currently in the process of doing the same thing. Look at the inside cover of the switch case. This is where the capacitor is housed and is attached to the motor. On the inside cover there is a wire schematic. Not a very good one. I have yet to fully trace out the current wire connections. Don't forget to change your plug. You do not need to replace the switch, just rewire input power to the motor.
Jan 13, 2011 | Delta 50 - 760 1.5HP Dust Collector
Hi! I have a delta dust collector model 50-850 and electric motor has like this little starter or i dont know what you call it, that started to throw smoke out of it, i had used it since but i need to find...
Look for the part here. From your description of the problem it might be item 21 (switch box) or item 26 (capacitor). If it is the switch box there may be additional part numbers to be ordered.
Dec 03, 2009 | Delta 50 - 850A Dust Collector with 2...
My 13 inch delta planer will not feed the stock through the planer. Any suggestions why?
I have a 12" Portable Planer Delta Model 22-540 - Planer will not feed the stock.
Sep 09, 2009 | Delta 22-450 20" Planer DC-580 3-Phase, 5...
Belt on delta planer
I went to Dewaltservicenet.com and looked at a parts explosion and also the instruction manual for this tool. The manual doesn't say anything about how to do it, BUT the explosion is good quality and should guide you thru replacement. Please let me know if I can help further and if I answered your question would you please rate it accordingly Thank you.
May 15, 2009 | Delta TP305 12 - 1/2" Portable Planer
Delta 22 - 547 12" Steel Knife Set for 22 - 540 Planer Logo
218 people viewed this question
Top Delta Cutter Tools Experts
Frank Mangiapane
Level 1 Expert
Joseph Hoffmann
JOHN LAPIER
Are you a Delta Cutter Tool Expert? Answer questions, earn points and help others
