Question about Kenmore Washing Machines
After f02 code came up ran a test and get c00 andhttp://www.fixya
After f02 code came up ran a test and get c00 and than f70 code on my kenmore elite he3t.
  • 6,784 Answers
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Posted on Sep 27, 2009
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
Jul 27, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Oct 24, 2009 | Kenmore Elite HE5t Washer
I have a kenmore Elite washer front loader HE3t and the error code f02 came up after unplugging the washer I havn't been able to turn it back on, ran an error report on it and it came up COO than F70 now...
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2009 | Kenmore Elite 45986 Front Load Washer
What does the code f70 on a kenmore elite dryer mean?
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Please report back here what you find, OK?
Aug 05, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
Our Kenmore Elite HE3 washer will not finish a cycle, flashing an error code of F02. Can you tell me what this is in reference to?
"F02" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In general, this usually means the drain pump or drain hoses are clogged and need to be cleaned. I have included instructions on how to do this as well.
It does not take much to damage these small pumps. Items begin caught in the pump impeller for extended periods of time can result in a pump that no longer runs, or one that no longer pumps at the correct volume. If cleaning does not solve your problem, the manufacturer recommends replacing the drain pump. Hopefully, a simple cleaning will solve this for you. Let me know if you have any questions, or require addtional assistance.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite eletric dryer model 8708
I've never heard of an F70 I have heard of an F07 which is possibly a motor controller error.
Nov 28, 2007 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
625 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
