Question about Jwin MP3 Player
When i plug my mp3 player into the usb port i get a message says that the security system has put the rcarip program into a low level area that would not allow the software to download to the computer in order to access the mps players software
  • 80 Answers
Try another compatible laptop or system. Because, sometimes some systems need a lot of drivers to be installed before they can work well for players like this. It has happened to me before.
Posted on Feb 17, 2010
Will not recognize unit via the usb cable
MP3 players use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing an MP3 player is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
Instructions
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Download updated firmware or use the MP3 Recovery Tool provided under Resources (mp3 players).
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
Aug 19, 2011 | Garmin Golf Logix GPS
My samsung yp-u5 mp3 player was not work properly.it attached the pc they shows not drive in the devise. so i want driver insatallation methode of samsung yp-u5 mp3 playe.
Instructions
Device Manager
Other solutions
Download updated firmware or use the MP3 Recovery Tool provided under Resources (for Zen players).
Tips & Warnings
Jun 15, 2011 | Samsung YP-U5 MP3 Player
HS-636-4GBBK MP3 player - computer does not detect it
Instructions
Device Manager
Other solutions
Tips & Warnings
Take care and hope it helped.
Jun 01, 2011 | Kobian HS-3245 MP3 Player
When i plug in my Transonic MP4 player a pop up box comes up which says that "USB device not recognised". It then tells me that one of the USB devices has malfunctioned and windows does not...
Instructions
Device Manager
Other solutions
Tips & Warnings
May 22, 2011 | Audio Players & Recorders
My i pod stack it says connect to your computer use itunes to restore i try to connect with my computer but it s not working .my itunes not recognize the ipod
Instructions
Device Manager
Other solutions
Tips & Warnings
May 16, 2011 | Apple iPod MA446LL/A MP3 Player
I have go gogear 4gb have a long charging cable and i put it in the computer wont regonize\no pop up windows?
Instructions
Device Manager
Other solutions
Download updated firmware or use the MP3 Recovery Tool provided under Resources (for mp3 players).
Tips & Warnings
May 13, 2011 | Philips GoGear SA5285/37 Digital Media...
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Jwin MP3 Player Logo
49 people viewed this question
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
