Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I am trying to turn the whirlpool space 4 american style fridge freezer on. the fridge seems to be fine, but the freezer side temp display is winking and the temp control is not responding and the warning light is flashing. Help?
  • 82 Answers
You have a common fault with the electronics.
Check on a large auction site for a repair kit.
Item number: 330363841350
It will only cost £30, better then a few hundred.
Hope this helps
Posted on Sep 29, 2009
HVACRH20
  • 237 Answers
SOURCE: problem with american style whirlpool fridge freezer
Did you ever get any advice for this problem? Please repost if not.
Posted on Dec 23, 2006
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
my freezer has defrosted itself and my fridge is not working, have turned it off and back on but no luck, will not get cold at all is only 3 years old!!
Posted on May 30, 2008
SOURCE: Flickering display panel on Whirlpool
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Posted on Sep 08, 2008
SOURCE: WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
Posted on Jul 10, 2009
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
I have whirpool fridge freezer american style and the temp lights flashing on and off wont turn off what can i be
Check the coil at the back of the freezer for ice buildup. Should there be ice build up, have it defrosted and cleaned. If that does not solve it check out the thermistor, also located at the back at a panel. It may have gone bad.
Nov 12, 2009 | Whirlpool Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Flickering display panel on Whirlpool american style fridge/freezer
Jul 16, 2008 | Whirlpool Refrigerators
Whirlpool fridge freezer (american style)
you have a bad control or bad sensor
May 11, 2008 | Freezers
Whirlpool side-by-side fridge/freezer continuous operation
have you cleaned the coils under the unit remove the toe kick in front and use a shop vac
Mar 04, 2008 | Refrigerators
Samsung side by side American style fridge/freezer
make sure your fan is running in freezer section. you should hear it
Dec 02, 2007 | Freezers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
769 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
