Question about Symphonic WF803 DVD Player/VCR
Dvd recorder won't record
The dvd player will not record, how do you make the dvd player record? I use dvd r+ disk to record.
  • Pastor P Feb 29, 2008
    Have the same problem... sounds like i'm just out of luck if the cleaner didn't work. The recorder is not that old and I only used it about 12 times before the error started popping up. UGH!
  • 4,402 Answers
I would try cleaning the laser first!
if that doesn't work try another brand of dvd's
if still doesn't work i would think the laser is weak.
Posted on Jan 24, 2008
  • 15 Answers
SOURCE: Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Posted on Sep 18, 2007
  • 12 Answers
SOURCE: Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Posted on Feb 27, 2008
  • 905 Answers
SOURCE: previously recorded disks and new disks all-dirty disk rejection
you may need to go thru the cleaning process a couple of times since it has never been cleaned ,but I'm glad there is a for sure improvement
that was my thinking about the laser lens cleaning disc , I have helped alot of people with thier player as well because they to did not know of the disc either. they do not advertise it enough for people to always hear about it or include the cleaning process and recommendations(maybe because they want you to buy a new one is about right!)
sometimes they get so dirty the laser lens has to be cleaned manually ( with a q - tip and the disc solution )
if you have anymore questions don't hesitate to ask
Posted on Mar 28, 2009
SOURCE: recorded dvd's won't play on other dvd players Toshiba d-r410
You can play these recordings without finalizing them in the D-R410, but if you want them to play
in other DVD players, they need to be finalized. See pages 28 to 32 in manual. If you want to
finalize the disks you've already made, follow the directions on page 32.
Posted on Jun 07, 2009
SOURCE: Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Posted on Dec 03, 2009
Why won't the DVD-RW disks FORMAT? I've seen others with the same problem with formatting multiple types of disks... Please help.
If you are using a Sylvania DV220SL8 DVD Player \ VCR combo (which this question is posted under the heading of) there is a very simple reason why you can't format DVD-RW disks. DVD Players can't do that. You need a DVD Recorder to format DVD's.
This applies to all comments under this heading as well. You can not record if the unit you're using does not have that capability. And this unit does not have it. You can record with the VHS VCR, but the DVD Player is just that... A Player. It's not a Recorder.
Sep 09, 2011 | Sylvania DV220SL8 DVD Player/VCR
What is the difference between a DVD+RW and a DVD-RW.
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording only plays recorded DVDs
May 08, 2011 | Cyberhome CH-DVD 300 DVD Player
I have had my sony rdr-gx257 dvd recorder for about a year now, never been used. I have been recording gameplay from my ps3 with it since yesterday. I have recorded onto dvd-r disk and dvd+r disk however...
After ending recording, Finalize recorded dvd as option is available in recorder menu.
a Finalized dvd will playback in other dvd players.
Dec 30, 2010 | Sony RDR-GX257 Player
My ilo dvd R/P will not record and keeps saying invalid disk,
Mar 08, 2010 | iLO DVDR04
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
Dvd keeps reading no disc
It can be several reasons
1. Disk is upside down
2. Lens is durty. You will need to use CD/DVD cleaning disk for that
3. Disk is having diffrent region code or recorded in diffrent formate (for instance player playback disk recorded in NTSC, and you trying to playback disk in PAL formate)
4.Disk is recorded at higher speed (for instanse player markered X16, but disk is recorded at X24)
Good Luck
Dec 24, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Nov 13, 2007 | Emerson EWR10D4 DVD Recorder
Open Questions:
Symphonic WF803 DVD Player/VCR Logo
116 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
