Question about Mongoose Mischief 20 Freestyle BMX Bicycle
I need a tyre - Mongoose Mischief 20 Freestyle BMX Bicycle
  • 62 Answers
You can go to kmart walmart or ****'s Sporting goods and get one
Posted on Sep 27, 2009
What's the tyre pressure for a caravan with 185r14c on it
It depends upon the type of tyre, whether you have a single or dual axle as well as the weight of the van when loaded.
The maximum tyre pressure for the type of tyre you have will be listed on the sidewall of the tyre. Given the weight of a loaded caravan I would recommend you run the tyres at 2 PSI under the maximum pressure listed on the tyre for a cold inflation. If the maximum is, say, 40 psi then run the tyre at 38 psi. Tyre pressures will increase when the tyres are warmed up from running so always check and adjust the pressures when cold and purchase a good tyre gauge to carry with you if you do not have one yet. Higher tyre pressures within max specification, will lower the tyre's rolling resistance and tyre heat build up, places less stress on the tow vehicle and will give better tyre life on the van tyres.
Tyres are maximum load rated so know the van weight and make sure you do not exceed the load limits of the tyres (printed on the side wall) when adding weight to the van, including water storage.
Tyre Sidewall Explained
Jun 06, 2016 | Cars & Trucks
My Pride colt XL8 mobility scooter has solid tyres can I convert them to pneumatic tyres
Hi yes think you can but you will need to replace all wheels and tyres
Mar 28, 2015 | Pride Health & Beauty
What is the correct tyre pressure for a 17 foot single axe pop top Regent caravan (tyre size 195-14)
I can calculate it with spreadsheet I made, call myself tyre-pressure specialist nowadays.
Depends on tyres maximum load and Pressure needed for that ( AT pressure 6pr 55psi/3.8 bar, 8pr 65psi/4.5bar or 69/70psi/4.75/4.8bar). and maximum speed of tyre given as letter mostly N to R for caravans.
Then from Caravan MPVW ( max permissable Vehicle Weight).
Or better real weight ( overloading is more rule then exeption and unequall load is possible.
But normal car tyres or XL/reinforced/Extraload are sometimes OK if they have enaugh maximum load for MPVW.
Will try to make picture of example.
Feb 12, 2015 | Cars & Trucks
Removing rear tire
Instructional video on how to remove the back wheel of a bicycle. All rights reserved to Trek Bicycle Corporation.
https://www.youtube.com/watch?v=wgAFLxYOmro
Mar 09, 2014 | Trek 8000
Where can i buy the tyres from
Send me the make and model and the serial# I can order them, you can send info to dfwmobilityspecialist@yahoo.com.
Apr 10, 2013 | Heartway Health & Beauty
My XR falcon ute needs new tyres but I have got an odd rim on one tyre
I would probably get used tire or tires until I could get all the same rims
Mar 18, 2013 | Cars & Trucks
Yahoo.comProblem with Tubeless tyre, one time it got burst, second times bubbles came out from tyre, I want to place tube inside tubeless tyre, can I place tube inside tube less tye and make it tube...
max speed with a tube inside a tubeless tyre is 75 mph.DO NOT EXCEED THIS SPEED for highway motoring.(hyundai make KUMHO tyres) THEY ARE NOT RATED FOR MORE THAN 100 MILES PER HOUR.YOU MUST USE TYRE RATED FOR THIS TYPE OF SPEED.check out michilin.com for tyre for ratings.
Aug 24, 2010 | 2009 Hyundai Elantra
Flat tyre
If you have the "Mini Mobility System" your car has a tube of tyre sealant and an electric air pump. These are locate in the boot (trunk) under the carpet.
Shake the tube of sealant. Screw the filler hose onto the bottle. Unscrew the dust cap from the tyre valve. Unscrew the valve insert from the tyre valve using the screw device (very important). Push the tube of tube of sealant onto the tyre valve and hold the bottle with the cap pointing downwards. Squeeze the bottle and force the entire contents into the tyre. Replace the tyre valve insert using the screw tool (most important).
Get the electric pump and connect the hose with the pressure guage onto the tyre valve. Connect the pump electric plug into the cigarette socket in the car or power outlet in the boot (ignition key needs to be on position 1). Inflate the tyre to 1.8 - 2.5 bar. Switch the pump off for a moment to check the pressure accurately. Unscrew the compressor, and put everything away in the boot. IMMEDIATELY drive your car for about 10 minutes. This is to distribute the sealant throughout the tyre. Do not exceed 60km/h. After driving for 10 minutes, recheck the tyre pressures using the pump or at a service station. Continue your journey but keep below 80km/h until you have the tyre checked or replaced.
Oct 11, 2009 | 2002 Mini Cooper
Need to reset to run flat tyre warning light on
i have a bmw , 1 series, i have just put air in my tyres and there is now a warning light on the dashboard, have i over inflated my tyres?
Jun 07, 2009 | 2005 BMW 3 Series
Mongoose Mischief 20 Freestyle BMX Bicycle Logo
41 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
