Question about Emerson Microwave Ovens
Model mw8109w just stoped .No display of clock or anything.
  • Emerson Master
  • 8,404 Answers
You have checked the circuit breaker - RIGHT?!?!? Looked for a tripped GFI?!?!?
Unplug the machine ... Remove the cover. DONT TOUCH THE SILVER CAN - LETHAN
Look for a fuse on the floor of your machine near where the cord enters. If you have a volt/ohm meter, check it with that meter. If you dont know what Im tralking about, get a paper clip, a flash light light and a flash light battery.
Bend the clip in a manner that will allow you to touch the both the bottom of the battery and the side of the flash light light while put place the metal tip of the light on the top of the battery. The light should lilght.
Now, place the fuse between the bottom of your battery and the end of your paper clip. If the light lights, your fuse is good. If it doesn't llight, your fuse if probably bad.
Get a replacement at an appliance or auto parts place.
I hope this solves your trouble.
a
Posted on Sep 27, 2009
FMT 148G1W2 model how to turn the clock off
Good Morning Friend, that's a great question!
The clock display on your Frigidaire microwave (FMT148GW2) may be turned off by pressing and holding "0" for about three seconds. You can redisplay the clock by pressing "0" again. Hope this helps! - Z
Jul 06, 2014 | Frigidaire FGMV174K Microwave Oven
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
Clock frequently goes blank and needs to be reset
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
May 21, 2010 | Hotpoint RVM1325WW Microwave Oven
How do you reset the clock on the microwave
press clear, press clock, enter time, press clock again.
Dec 09, 2009 | Microwave Ovens
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
Aug 03, 2009 | Sharp R-1460 Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
381 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
