Question about Kenmore 22422 Top Load Washer
WASHING MACHINE LEAKS WHEN WASHING & SPINNING
    Problem Solver:
  • 5 Answers
Replacing the drain pump is EASY--it was right in front and literally clipped on to my machine. By far the most difficult part is getting the casing off and back on the washer itself.
Posted on Jul 28, 2008
  • 32 Answers
If you tip the washer back and look under it you may see water coming out of the pump if so replace the pump
Posted on Dec 18, 2007
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Not spinning properly there is still a lot of water in clothes after spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Admiral Washing Machines
My whirlpool AWOD4606 washing machine won't spin when washing or spinning
heatman101
Apr 13, 2011 | Washing Machines
Washer leaks out the bottom in rear of machine
Thank you for using FixYa. Does water leak out of the machine from the beggining of the cycle to the end? If it only leaks when spinning or Pumping out water and water comes from the rear bottom of the machine? This is where the drain pump is located and I would say that the leak is coming from there---either a perished hose or a loose retaining clip.
Mar 16, 2011 | LG WM2101H Front Load Washer
Washer isnt spinning out does drain but not spinning at all
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 29, 2010 | Washing Machines
Miele dryer leaks water.
sounds like a washing machine problem
its not spinning clothes dry
Jun 08, 2009 | Miele Dryers
Washer leaks and keeps shutting off when it starts to spin.
 it sounds like your washer is not draining before it starts spinning. the machine should not have visable water in it when it starts to spin. make sure there is no water in the machine and that it is draining properly.
Jan 27, 2009 | Kenmore 23822 Top Load Washer
Washing machine is not spinnig out the water
Does your washing machine spinning? if the washing machine is spinning and the water won't out, the release valve didn't open.
If the washing machine is not spinning, the fin belt broken.
Jun 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
My washing machine leaks
No it will not explode on you, what may happen its that the boot or clamp its loose this happens when you move the machine from one place to other. You could open it up and check under the tub, but with the plug out of the out let. also check the tubes which that is hooks up to the drain pump.
May 12, 2008 | Washing Machines
Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Feb 10, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
