Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Dishwasher not working right
Dishwasher does not seem to be using all the soap detergeant and dishes are not getting cleaned well
    Genius:
  • 1,003 Answers
REPLACE TIMER
Posted on Jan 18, 2008
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Soap dispencer door dosnt seem to be opening at the right time. i find the soap undisolved in the bottom of washer, and dishes are not clean.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Feb 09, 2011 | GE Nautilus 24" Built-in Dishwasher
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Maytag dishwasher
Go buy a product called Lemi-shine and run it thru your dishwasher empty to clean out any hard water and soap deposits. If you can try using only about 2 table spoons of detergent and stay clear of the premeasured tablets. Most of the dishwashers being sold are low water usage units and it is very easy to overwhelm them with soap. It also helps if the oils from the foods are still on the dishes. People tend to clean the dishes to much before loading them and then the enzymes in the detergent have nothing to attach to. Basically this leaves the soap nothing to attach to except the dishes and hence you get cloudy dishes with soap stuck all over them.
Jan 30, 2010 | Dishwashers
Dishwasher doesn't wash dishes right
The solenoid that opens the detergent door may have had water leak into it. Remove the inner panel from the main door, remove the solenoid mechanism and it's core. With the core out, clean the solenoid interior and the core surface with hot water. The core should fall out of the solenoid by gravity if it is clean. DO NOT OIL THE CORE OR SOLENOID. If there are signs of water entry to the solenoid, check the detergent dispenser seal for damage. Try using a tab type of detergent rather than liquid or powder. Make sure the release mechanism is clean as well. Hope this repairs your problem!
Dec 29, 2009 | Frigidaire FDB1050REM Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
116 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
