Question about Izzy Cameras
How do I get the pictures from my mac computer into the frame? I have no instructions
  • 739 Answers
The question as posted with the title is a little vague.
I'll work on the basis that you have a digital picture frame and you want to get the pictures from your Mac on to it.
First examine the picture frame for any obvious connectors or card slots. Once you have determined what connectors or slots are available then find a means of connecting to that connector or slot - it could be a simple as a USB lead, using a pen drive or using a camera card. If it is a USB lead then I would expect the frame to appear on your mac like an external drive when you plug it in. Then drag your chosen pictures from iPhoto onto the frame's icon./ If it's a pen drive use the same method but substitute the pen drive for the cable & frame, similarly if it's a card slot - although you'll have to identify which type of card it is.
Finally, if you cannot find any connectors other than a power connector, then it could well be a bluetooth job and you will have to use the bluetooth on your mac to do it. Use the Mac's help menu to show you haw to connect to a bluetooth device.
Posted on Sep 27, 2009
I use a mac. Have all pictures stored on iphone and would love to know how to get the photos to my photo frame. Not sure how to get pictures from iphoto to a memory card or whatever it is I need to do.
Use iPhoto to get the images off your iPhone and onto your Mac, then export you selected images to a media format the photo frame support.
Now without knowing the requirements of the photo frame but going to guess it accepts and USB thumb drive. Once you have imported your images into iPhoto from your iPhone, plug in the USB thumb drive to your Mac. In iPhoto, select the images you wish to move to your photo frame ( either select an album or individual images). Then go to the File Menu and pull down to Export and save the images to your Thumb drive. For best results for image quality on the photo frame you will want to match the export size with the native resolution of the photo frame.
Apr 24, 2011 | Office Equipment & Supplies
My Grandma was given a Coby dp700 with pictures already on it for a gift. She would like more pictures. I can get different pictures from a usb flash drive to play as long as the flash drive is plugged...
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
Mar 05, 2011 | Coby DP-772 Digital Picture Frame
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
I want to dowload some picture from usb on the picture frame
you probably have 2 possibilities..
1st ) is to insert the stick ..(card with the picture on ...and choose to play the slide show from it )
2nd) is to connect it to the computer ...and after that the computer will recognize it ..and you will find it in my computer folder by its name or as a removable device (this mostly in case it has a card attached)
Open the folder and inside you will be able to see the pictures that are already there ...top Load pictures just drag and drop pictures in this folder or copy and paste them..after that you will be able to see them on the frame ...make some slide shows with different folders ..or just play all..and it will change them on a preset time ..
Same thing for Mac..bu the frame will be visible on desktop..and same just copy pictures into it(be sure you do not cut them cause you will loose from computer this way ..so ..just copy ..and paste into the frame's folder
May 31, 2010 | Kodak EasyShare SV811 (8858946) Digital...
Transfer pictures from memory card
Ok what you need to do is you need to put your memory card into your computer/mac and down load the files once that is done delete the photos on your camera!
Mar 27, 2010 | PANDIGITAL 6.0-Inch Digital Picture Frame...
How do I get pictures from my computer (Mac) to a memory card.
Connect your cam and turn it on. The camera should appea as a device and you can download or upload onto it as you wish
Oct 14, 2009 | Kodak EasyShare SV-710 (8370181) Digital...
Comp does not recognize the connection
There was a corrupt file on the picture frame that needed to get deleted. The corrupt file was not allowing anything to work properly.
May 07, 2009 | SmartParts INC. digital frame. 7.0 in....
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Nov 25, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Trutech 7 Digital Photo Frame.
Try a new unformatted SD card (now they are around $10/1GB).
Jan 12, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Cameras Logo
94 people viewed this question
Top Izzy Cameras Experts
Are you an Izzy Camera Expert? Answer questions, earn points and help others
