Question about Homelite Mighty Lite Lawn Trimmer
I have the Mighty lite UT21506 weed eater with the pull cord spring that need to be re-wound. Please help me by telling me a location or manual showing how to rewind/how to replace the spring.
steve_lima
  • 181 Answers
SOURCE: weed eater wont start,put straight gas in it.
if you didn't mix any oil with the fuel,you probally burnt the piston and cylinder up.the only to find out if you did is to pull the muffler off and look inside the cylinder and see if there are any scoring on the piston.if there is you need to replace the piston and cylinder assembly.most cost $100.00 or more.usually they are not worth repairing.i know this is not good news but i hope this helped,let me know.................
Posted on Jun 02, 2009
SOURCE: I need to rewind the spring and starter pull cord.
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Posted on Aug 28, 2009
  • 396 Answers
SOURCE: can not rewind spring on my homelite weed eater
Those things can be a terror to get back in place once they have escaped captivity.
You likely would be better off to get a new part with the spring properly in place. You will then avoid a lot of frustration.
Posted on Oct 10, 2009
  • 56 Answers
SOURCE: I have never been able to start my homelite mighty
First thing is to remove and clean the spark plug...remove carbon deposits or gummy residue (a shot or two of carb cleaner should do it !!). Check the gap on your plug to see if it is somewhere between .025 to .030 (if you have your manual it should tell you the proper gap space...if not google www.homelite.com and they should be able to give you the answer). Next re-attach plug to plug wire and place the plug base touching the cylinder head...pull start handle and see if you get a blue spark...if not then you've got a faulty magneto or a bad plug...if you have spark,open the throttle and pour about a teaspoonful of FRESH fuel mixture into the throat of the carburetor. Hold throttle open and pull start handle a few times...the engine should start and run for a few seconds...if it does then the problem lies in the fuel system. Check fuel filter inside tank...check fuel cap vent to make sure it is not clogged...check fuel lines (may be gunked up or de-composed) squeeze primer bulb to be sure gas is reaching carburetor and to make sure it has no holes or tears. Put fresh fuel in tank, choke set to full, and try to start...may take a number of pulls of the start handle...if it starts, you're probably OK, you may just have to re-adjust your carb a little...if not the problem is probably a trashed up or gummy carburetor...(you will have to clean it or rebuild it). good luck !!! ;-D
Posted on Jul 06, 2010
SOURCE: Have lost a spring and so therefore line won't
Ebay... Parts interchange with Ryobi...sometimes
Posted on Jul 29, 2010
The head keeps falling off my weedeater brand weed eater
Add a split washer. Turn it tight enough to compress the split into a flat washer. The spring tension of the washer will hold it on. If not, you will need to add some Loctite.
Apr 17, 2014 | Homelite Mighty Lite Lawn Trimmer
Need to know the gas ratio to use in a homelite(trimlitr) weed eater.
50:1 if that is too rich the weed eater will give off white smoke then use 30:1
Jun 18, 2011 | Homelite Mighty Lite Lawn Trimmer
I was given 2 weed eaters, the z830sb, and the d630cd. I need to know what the gas and oil mixtures are for these units.. Thanks Jim
32:1 should be a good mixture for the homelite weed eaters. here is a thread on it, hope it helped Tim:
ttp://forums2.gardenweb.com/forums/load/tools/msg1011591014681.html?13
Apr 24, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a MightyLite weed eater - the plastic bobble has a crack. What are my options besides purchasing a new weed eater? Purchased at Home depot.
You don't have to purchase a new one. Parts for it are available. This online parts house is good. If you are saying you need the plastic bubble for the carburetor, it is here.
http://www.ereplacementparts.com/homelite-misc-parts-c-18807_24213.html
There are 3 models listed. They are listed in the 4th section of misc. parts and are items 9,10, and 11.
All the other parts for your machine are listed here too:
http://www.ereplacementparts.com/homelite-ut21506-mightylight-string-trimmer-parts-c-18807_20299_64844.html
Oct 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
Can not rewind spring on my homelite weed eater
Oct 10, 2009 | Homelite Mighty Lite Lawn Trimmer
My starter pulley was broke i replaced it with a
If it was installed correctly, it is a defect. Have your supplier replace it. You may have to pay freight. Good luck...Lee
Oct 01, 2009 | Homelite Mighty Lite Lawn Trimmer
How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Jul 25, 2009 | Black & Decker Garden
Homelite weed eater model rx70
you can go to this website and find your trimmer manual. hope this helps.
http://www.homelite.com/service_support/order_parts
Tobaz
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
477 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
