Question about Kenmore Refrigerators
Leaky ice and water dispenser connections - Kenmore Refrigerators
  • 6,784 Answers
HI, this will occur if there is debris present inside the inlet valve structure that is preventing the inlet valve form completely closing itself when not in use. the will cause a small amount of water to leak through the lines. This could also be a damaged valve as well(mechanism failure).
I recommend to inspect this valve. The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Sep 27, 2009
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
SOURCE: Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Posted on Nov 09, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
tborn6
  • 700 Answers
SOURCE: Subzero 685 water dispenser won't work
check the water resevour it is probebly frozen up arpound the outlet of it. its inside of the refrigferator, towards the back of the refrigerator down towards the bottom. take a hair drier and thaw it out.
Posted on Jan 16, 2009
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
What is causing the water dispenser to drip? Ice is making fine
most likely a leaky water inlet valve or clogged dispenser defrost pipe or water tank leaking or water filter leaking.
Aug 06, 2014 | Samsung RS2630SH Side by Side Refrigerator
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
Water dispenser freezing
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Apr 01, 2010 | Refrigerators
Water dispenser not working, but icemaker is working
Mar 30, 2010 | Refrigerators
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water is not despensing
Try these:
  1. Check the water dispenser arm. It must have some resisting force when pushed or pulled. Otherwise it is defective, then replace it.
  2. Check the water line and water inlet valve for clogging. It can cause poor water flow, undersized ice cubes and overfilling. Replace if found defective.
Note: The ice and water dispensing system of your refrigerator is complex. Aside from simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. Service of a qualified appliance repair technician is suggested for such repairs.
Aug 31, 2009 | Whirlpool Refrigerators
Water does not come out of the water dispenser
Hi!
In most of the cases the issue you are facing with is usually caused due to one of the following reasons:
1. Inadequate water pressure.
2. Kinked tubing between the valve and the dispenser outlet.
3. Dissolved air or gases in the water supply.
4. The slight expansion and contraction of the reservoir as it warms and cools frequently.
The ice and water-dispensing system of refrigerator is a complex one. Many components work together to provide the ice and water. The problem may be simple like leaky water tube or a jammed ice chute. Please check all of the above things to resolve the issue. Unplugged the Refrigerator for 4 to 24 hours and it may also resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | Whirlpool GD2SHGX Refrigerator
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not filling up
happened to me. leaky solenoid assembly located at back of unit, easily replaced. see fixitnow.com
Jul 08, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
