My whirpool ultimate care 2 lsq7533jqo will not drain or spin?
SOURCE: whirlpool imperial series 2 ultimate care washer
Jewel 42 I had a similar problem with mine, it wouldn't drain or spin. It was the sensor/lever that lets the machine know that the lid is closed... the screw casing that held it in place had broken... I tied it back in place covered the string with duct tape and now it works fine... or at least it did until the pump cracked this week.
SOURCE: Whirlpool ultimate Care II will not spin and makes a loud noise
The usual culprit is the motor-transmission coupler. This is located between the motor and the transmission. You need to remove the pump and then the motor to access it.
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
SOURCE: whirpool Ultimate care II
your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
SOURCE: Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
