Question about Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 gps
Failure to acquire satellites
  • CCoastGuy Dec 19, 2007
    Garmin StreetPilot C330 GPS screen says Locating Satellites after selecting view map or choosing a destination. I have tried to reset and it comes up with the same problem.
    Problem Solver:
  • 4 Answers
I have had this unit for 2 years now and it has been working flawlessly until the battery went dead. I replaced the battery using a suggestion found on this site with a 3.7 volt Lion 2600mah unit and that problem is solved. Now I get bad satellite reception. I have double checked the installation of the gps module with the can facing down and the gps antenna facing up. I did both the under the bezel reset and the master reset holding down the right corner while turning on the unit and completed both successfully. The unit does get a signal intermittently and I lose signal quite often and it asks me if I am indoors, etc. Do the gps modules go bad? This went from a fast starting up and locking in unit to a piece of crap that seldom receives the satellites. Any suggestions????
Posted on Dec 21, 2007
  • CCoastGuy Dec 21, 2007
    I have found a solution for my failure to acquire satellites! Apparently, the extremely tiny coax that connects to the gps module from the face unit has an extremely fragile shielding. The shielding is used as a ground and along with the center conductor gives you a signal source and a ground, coax. On my unit the ground shielding had seperated which required unsoldering the center conductor and ground and redressing the connection and then resoldering the center conductor and shielding to the gps module. Once repaired my gps gets 4 bars and is up and ready for navigation in under 2 minutes! I had to use a magnifying glass to see that the shielding had seperated since this coax is like 24 guage or something extremely tiny. I would imagine that without too much jostling around over time these tiny ground shielding wires could vibrate to an open connection for the ground. When I redressed and resoldered the connection I also took some electrical tape and taped the wire down similar to the way the remainder of the wire is taped on the face unit to prevent the same problem (I would imagine).
You have to be outside with a clear view of the sky for it to acquire satellites. No trees, no buildings, no hills, etc...
Posted on Dec 19, 2007
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
My garmin wont acquire a satellite signal what do i do to get one
The unit must be in clear view of the sky....thats where the satellites are!!!!
Jan 08, 2010 | Garmin StreetPilot C330 GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmnin C330 slow to acquire satelites.
Make sure you are not moving. This way it can triangulate better. Wait for it to recognize at least 3 satellites. Then cruise as you wish as soon as it is synced with the satellites.
Also, be sure that you are on an open field with minimal aerial hindrances.
Your problem is normal to all GPS devices. It does take time to acquire satellite signal.
hope this helps!
-levibit-
Mar 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
To reset the unit, pry off the silver faceplate.
Turn the unit on using the power button on the right side.
Press the reset button that was hidden behind the face plate.
The GPS unit should restart, and display its software version.
Make a note of the software version in case you have to call customer service.
To acquire satellites make sure the GPS has a clear view of the sky.
For Garmin customer service, call 800-800-1020.
You can also go to this link for complete customer service info:
Garmin Customer Service
Good luck, please rate this response favorably.
Jan 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
