Question about GE Kitchen Ranges
I have a Spectra XL44. I want to self-clean it. The door does not have a latch but it is supposed to lock automatically. It didn't lock when I started the self-clean. I stopped the self-clean. Now I have message "locked door" that I can't get rid of.
  • annekravet Sep 27, 2009
    But when I started the self-clean, the oven did not lock. And now as I've restarted the self-clean, it still is not locked.
    Yes that's correct - it's not locked but the message says "locked door". And it didn't lock when it was on self-clean.
  • 127 Answers
Hi there. I believe the problem with your stove is that you did not let the cycle finish and it is staying locked for safety reasons (cleaning cycles can contain toxic chemicals). You should re-start the clean cycle and let it run it's full course. If you need more assistance do not hesitate to reply to this/contact me.
Posted on Sep 27, 2009
  • ag66339
    ag66339 Sep 27, 2009
    So basically it's not locked, but says that it is locked. Correct?
  • ag66339
    Try resetting the board unplugging the stove for a few minutes. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER.
    This should fix the problem.
How do you turn off the self cleaning oven when door is locked on the GE Spectra XL44
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 14, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 oven. How do you latch the oven closed for self-cleaning...there is no lever.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Sep 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Self-Clean Cycle --- Lock Door Light Flashes
the door lock should be automatic just set everything and push start
Mar 30, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44
unit needs to cool down to release the latch assby
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
