Question about Gateway MT3705 Notebook
No video display on Gateway 340ua laptop
Was working great at home. Brought to work and powers on, but no no video display
  • 105 Answers
Ah you are the great blind Bill are ya LOL
Ok let me think foir a second and evaluate your options. OK check this link http://support.gateway.com/s/Mobile/2007/Apache/1014142Rnv.shtml
Now read this carefully and fully feel what im saying
Ok here is a possible cause and warning pass it on
Laptops a delicate even thought they are made from cast plastic and metal
Validate the waranty ok
Here we go again the display on laptops and microthin displays are run with ribbon cable you need to cary this hardware like there are eggs inside when your ruff with them connectors may come undone and possible tear if you are tach sharp then i would say crack the case (disassemble) my english sucks
Carefully with a polaroid take a picture so you dont forget the assembly of the box now look down by the hinge area for a loose ribbon cable (its flat maybe colored or clear not sure) it connects to the vdu ( graphics card basically) on the motherboard it may have disconnected at the video terminal also so check there also and treat this like nitro man anyway if this sounds a little tuff im sorry
But you can get it serviced if the warranty is still good and it wont cost you anything but time and gas
( Good luck i feel your pain )
Posted on Oct 20, 2009
  • 43 Answers
Again, if you can see the video using an external monitor, either your screen, LCD Inverter, or LCD video cable is bad.
If you cannot see the video using an external monitor, your graphic chip on your motherboard is shot. Your laptop is on life support. Pull the power adapter out of the wall and let the machine die.
You can reflow the BGA CHIP. However, the life span on those reflow are short and the graphics are sometimes compromised.
If you feel like reviving the patient, go straight to the chest with a defibulator. However, that will last just long enough to get the patient to emergency surgery will little change of returning to a normal life.
Get a new laptop, or repair it knowing that it will die without notice.
Good luck
Posted on Sep 27, 2009
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
After using my laptop(Gateway NV53) for about 5-10 minutes the screen will turn black or the screen will freeze. Non of the buttons works after this and the only way for me to reboot the laptop is to pull...
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power
setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc,
Jul 01, 2010 | Gateway NV5387u Notebook PC
I spilled juice on my gateway T-6330U laptop keyboard. I shut if off and pulled the power cord. I noticed it trying to boot up when cleaning it off, the LCD was fadding, and I heard sizzling under the...
Check the video connectors on the motherboard.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 21, 2009 | Gateway T-6330U Notebook
I have a 7322gz gateway laptop.back lts work but nothing displaye
On most notebooks, switching between the internal display and the external display is done by pressing Fn+F4.
Aug 02, 2009 | Gateway 7322GZ Notebook
Mortherboard,keyboard replacement on gateway m360
First I would ensure my video cable was firmly connected. Sometimes that connector does not seat all the way causing what you are seeing. That is the rectangular connector leading fro the cable on left side of the LCD to the motherboard. Normally there are several hardware components related to a white display. LCD, video cable, or motherboard all causes of white screen. Have you checked external video? What was the original issue before motherboard and keyboard replacement?
Mar 14, 2009 | Gateway M360 Notebook
New laptop lcd display not working
check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Feb 18, 2009 | Gateway MT6451 Notebook
No video screen at all in mt3422 gateway laptop
Unlikely. Most systems won't boot without a working display card, you'll get a beep code. USB video only works on a fully booted system so the operating system can initialize the device and load the drivers.
Feb 08, 2009 | Gateway 7405GX Notebook
COOLING FAN DONT WORK ON DELL XPS M2010
call the dell tech 18006249896 they will be the right people to talk to
Jan 12, 2009 | Dell XPS M2010 Notebook
Gateway MT3705 Notebook Logo
850 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
