Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Want to hookup westell mod 327D modem/router to my desktop to use as a wireless router for my laptop . Also , what is the differance between the blue ethernet cable and the yellow ethernet cable besides the color ?
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. there is no difference between the yellow and the blue ethernet cable, its just a color coding so that you will know which device you are goint to hook it up. good luck
Posted on Sep 29, 2009
    Problem Solver:
  • 17 Answers
The cables are the same, and the color is just to remind you which one goes to the DSL modem (or other Internet source) and which goes to your local network (LAN). Often the ports on the router are color coded the same way.
To make your connections, just connect the desktop to a LAN port on the router, and connect the laptop by wireless, there's nothing special there. The quick setup information for your router should describe just how to set it up, so be sure to read it.
Posted on Sep 27, 2009
What's the difference between a modem and a router?
A modem in a nutshell translates computer network traffic into in your case an analog signal that can be carried over the phone line to centurylinks central office in your area. A router is designed to route in a home setting, IP packets within your home network. So you need a router in share that modem connection.
Nov 27, 2012 | Computers & Internet
Problem with NETGEAR Wireless router WNR2000 and DSL hookup. If I run westell 6100 DSL router independentlly on my desktop [windows XP] it works fine. But when I go thru the netgear router, both my Desktop...
1. If you can upgrafe firmware on router that can fix your problem
2. you can go to netgear website for latest firmware on router(you can download from there)
Mar 03, 2010 | NetGear WNR2000 Wireless Router
Do i need a wireless router if i have westell 6100f
Yes. The Westell 6100f is not a wireless modem, therefore, you will need to get a wireless router to connect wireless computers.
Or if your ISP is Verizon and you want a wireless modem/router, you may contact them and replace the Westell 6100f with a Westell Versalink 327w, or Westell 7500, or an Actiontec.
Hope this helps!
Mar 01, 2010 | Westell Wirespeed LiteLine 6000 Modem
I HAVE A WESTELL VERSALINK MODEL 327W IWANT TO CONNECT TO MORE COMPUTERS TO IF DO I HAVE TO HAVE SOME TYPE OF ADAPTER IN ORDER FOR IT WORK
your westell is a modem/router which means you can hook up more computers wirelessly.
yes, if you're using a laptop make sure it has a wireless card and for desktop computer..you have to have a wireless adapter...
Feb 09, 2010 | Westell Wirespeed VersaLink...
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Desktop and two laptops won't work with modem & router now
Probably you used the wrong type of ethernet cable, a crossover one. Try another Ethernet cable but this time a straight one.
Mar 11, 2009 | Westell Wirespeed ProLine 6100 Router...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
I have a westell versalink 327w date on the bottom is 07/2007
You'll need to go into the administrative interface of the router and enable the wireless network and then you should be able to see if from any laptop/PC with a wireless networking card in it.
Feb 05, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
229 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
