Question about Garden
I Have MTD riding mower is backfireing through air filter sounds like it does when u try and start up in reverse
  • 8,404 Answers
You have a time problem.
Set the timing to factory spec and your trouble should go away.
This process involves lots of work, particularly if you dont have the proper tools.
You will probably have to remove the engine cover and fly wheel for starters.
Once inside, you will need to read the markings and know how to use a feeler gage.
You might find additional help at the web site of the engine manufacturer.
While I dont want ti discourge you, this might be better done by a mower repair place in your town.
Good luck on your project.
a
Posted on Sep 27, 2009
2007 riding mower John Deere backfires while trying to start will not start
Inspect/replace the air filter to ensure proper air flow.
Inspect/replace the sparkplug(s) to ensure proper firing.
Check the position of the "choke" (if equipped; & by the way, most riding lawn mowers do not use a primer bulb button to prime the engine before starting).
Jul 03, 2015 | John Deere Garden
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
Mower will not go into drive or reverse White riding mower
bad hdro pump but first try and change hydro oil and filter sometimes it works
Jul 06, 2014 | Mtd LAWN MOWER PART # 683-04163B FRAME...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
This mower backfires. Will not start unless flywheel is advanced manually. Now it dies after running a few minutes. The fuel filter has been replaced, and air filter is not unduly clogged. What gives?...
for openers i would start by having someone check the valve clearances. sounds like you are out of time, and that is a common issue with a mower over 3 years old. if the intakes are opening way to late, and not far enough, you have a problem.
Sep 09, 2011 | John Deere 22HP Hydrostatic 42" Riding...
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Craftsman riding lawn mower tries to start and just putters then it backfires and shuts down.
it sounds like its the exhaust is blocked up or/and air filter, its the back fire that makes me think its a blocked exhaust,, iv had it before!
try taking it off and starting it up,,,,and yes its going to be noisy if it go's! untill you clean out the pipe, then put it back on again,
Nov 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Engin fogs the neiborhood with air filter on.
Sounds like it's pulling oil by the rings/valves -- the air filter is creating more suction. I would try a small amount of an oil additive for high mileage engines. Follow the mixing/proportion directions on the bottle. Sounds like this engine is "wearing out".
May 07, 2009 | Mtd Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
