Question about HP Compaq Presario C500t Notebook
My c500 presario won't charge and i think it's the charger. But when my battery went dead other times and i try to turn it on the lightning bolt indicator would always blink for a few secs. But now it just doesn't do anything. My charger is a replacement and it's in reallly bad conditions. Any thoughts would be appreciated
  • jjambert Sep 27, 2009
    Thanks for the fast help. Why the dc jack? what really has me worried is that the indicator is not blinking when i press the power button. Is it possible that ALL energy was used therefore it's not blinking? Or is it suppose to blink ALWAYS? I know my charger is was giving me a lot of problems.
  • 43 Answers
You probaly have a broken DC JACK on the motherboard. Therefore, regardless if you have a good power adapter. The power is not making a connetion to the battery because the DC JACK throught which the power flows is broken.
Try another adapter and remove the battery. If the computer is powered up using the new adapter then the old adapter is bad and the DC JACK is good. Replace the battery and if the batter charges, you can identify the old power adapter as the culprit. If the batter does not charge but the laptop powered on. Then both the battery and the charger is faulty-battery not holding charge.
Good luck
Posted on Sep 27, 2009
Testimonial: "Thanks for the help. "
  • Ken91025 Sep 28, 2009
    As previously stated, if the battery does not have a power source eventually it will drain and zero out. Thus, no led lights will power on or blink. Battery is dead. If you have a know working power adapter and you still cannot power on the computer then you probably have a broken DC Jack preventing the power from flowing to the battery and throughout the motherboard. You must test with a know working adapter.
    Good Luck
    President:
  • 2,600 Answers
Ant doubts in the charger should be accepted as fact and a new one purchased. A bad charger can have very nasty repurcussions on the motherboard, battery and other sensitive components that rely on a stable, consistant power source. Ebay is an excellent resource for chargers. There is an Ebay store called Monster battery, that sells chargers with extra long cables. Most chargers are priced in the 30-40 dollar range.
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Battery on permobil will not charge
First off, a Permobil C500 is not a PC laptop. Next time, please put this in the correct category.
Try charging up the battery/batteries with a auto car charger. Make sure the voltage is set correctly, and charge it on slow or low, 2Amps. Leave it on there for about 4 hours and see if the chair will run and for how long.
This should tell you if its the batteries or charger that's bad.
Sep 25, 2012 | Computers & Internet
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
Blackberry storm wont turn on or charge red light blinks constantly is there a physical reset button
This may work. Mine was doing the same thing this morning so I was looking through forums to no avail.
I have been using my USB charger since I got my Storm as I left my wall charger in another city and only just got it back...
The phone would do the same thing when I tried to charge (off USB) depsite pulling out battery etc.
I went home and plugged into wall charger and left it (maybe 20 minutes?) and a battery with a lightning bolt followed by the loading page and it is now back to life...
Hope this works out for you!!
Jun 09, 2009 | RIM BlackBerry Storm 9530 Smartphone
My compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Apr 03, 2009 | HP Compaq Presario C500t Notebook
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Presario C500 Wont turn on
sounds like the d/c adapter was either installed backward or the wrong part was installed, also check the connector on the new power cord to the laptop, you may have gotton an incorrect power cord. because what you describe is the internal power system is shorting out. take battery out and check it with a volt meter , if the is no volts/or negative volts on the battery ,it has gotten internaly reversed , and needs replacement.
Mar 25, 2009 | HP Compaq Presario C500t Notebook
WHY WONT MY 7280 CHARGE OR TURN ON
The red light indicates its charging.  My guess is that the battery is dead and will nto hold a charge.  This is an older model phone and the lives on the batteries is 1-3 years at most.
Jun 04, 2008 | RIM BlackBerry 7280 Handheld
Comp will not turn on also see lightning bolt display
Hi All,
This happens because of static energy storing in the motherboard components.
We can try power drain to resolve this issue.
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
That should resolve the issue, if the issue persists, then you have to contact service center.
Hope that information helped you!!
Apr 16, 2008 | HP Compaq Presario C500t Notebook
Battery doesn't charge
Is that the original power cord for that? Or was that one bought aftermarket, some aftermarket chargers will only power your laptop and not charge.
Mar 12, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
647 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
