Question about Epson Stylus Photo R340 InkJet Printer
How do is set up printer to print wireless? - Epson Stylus Photo R340 InkJet Printer
How do I find the Printer IP address
Test the wireless connection
Print the wireless test report for information about the printer wireless connection. The wireless test report provides information about the printer status, hardware (MAC) address, and IP address. If the printer is connected to a network, the test report displays details about the network settings.
To print the wireless test report
1. From the printer control panel, touch (Wireless), and then touch Settings.
2. Touch Print Reports
3. Touch Print Wireless Test Report.
Apr 09, 2016 | HP Officejet Pro 8610 Wireless All-in-One...
STOPPED PRINTING FROM MY WIRELESS LAPTOP
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you.
Feb 16, 2011 | Office Equipment & Supplies
My hp7280 all in one printer prints a blank page when printing from wireless and is ok when i print from hardwired destop
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you.
Dec 21, 2010 | HP Photosmart C7280 Laser Printer
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
I just bought a lexmark pro205 printer and It will not print?
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your Brother wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you.
Oct 26, 2010 | Lexmark Prospect Pro205 Wireless...
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Wireless hp j4680 printer will not print...offline help....
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you. get more help......... http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Wireless-not-working/m-p/319330#M19085
Sep 12, 2010 | HP Office Equipment & Supplies
Cannot print on wireless printer
..goto setting and disable the wireless setting on your printer.. then you should be able to print..
May 22, 2010 | Epson Artisan 800 All-In-One InkJet...
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Epson Stylus Photo R340 InkJet Printer Logo
13 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
