Question about HP Officejet Pro L7680 All-In-One Printer
Can't get the L7680 to duplex scan from the automatic feeder. It keeps giving me a error message and kicks me out of the program.
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
Posted on Feb 10, 2008
IB4G2008
  • 3587 Answers
SOURCE: "Scanner Failure" message
sure..new drivers might make this happier..
check your warranty here for FREE
Posted on Feb 23, 2008
Arius
  • 446 Answers
SOURCE: HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Posted on Jul 14, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    SOURCE: No Paper in Document Feeder
    plz send solution of document feeder error on my email id its urgent, i shall vry thankful to u .
    Posted on Sep 15, 2008
    Tip
    ERROR codes Canon 3725
    Canon 3725 E000 Fuser problem E010 Drive E030 Counter E050 Duplex side to side problem E051 Duplex side to side problem E200 Scan problem E202 Scan return problem E204 Scan E210 Lens problem E220 Blank lamp open or lens home problem E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
    on Jan 18, 2010 | Office Equipment & Supplies
    Tip
    ERROR codes Canon 3525
    Canon 3525 E000 Fuser problem E000 Heat E010 Main motor, motor board, clock pulse E010 Drive E030 Counter E030 Counter E050 Duplex side to side problem E050 Duplex problem with cross alignment E051 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E202 Scan home sensor or home scan E204 Scan E204 Document sensor, scan reverse sensor or scale E210 Lens problem E210 Lens E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E400 Document feed problem E500 Sorter E620 Editor E620 Editing problem
    My HP officejet Pro L7680 cannot scan anymore. It keeps saying: "Reload the Document & restart the job. And when scaning through PC then give an error msg: "The automatic Document deeder is...
    does the feeder try to fed the paper? if you hear not working and not fed the paper then clean with alcohol with hard paper the roller .
    if not fix did you hear noises? maybe the gears.
    hope i help
    Dec 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Tip
    ERROR codes Canon 3225
    Canon 3225 E000 Fuser problem E010 Drive E030 Counter E050 Duplex side to side problem E051 Duplex side to side problem E200 Scan problem E202 Scan return problem E204 Scan E210 Lens problem E220 Blank lamp open or lens home problem E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
    Tip
    ERROR codes Canon 3025
    Canon 3025
    E000 Fuser problem
    E000 Heat
    E000 Fuser problem
    E010 Drive
    E030 Counter
    E030 Counter
    E200 Scan problem
    E204 Scan
    E210 Lens problem
    E210 Lens
    E220 Lens
    E240 DC controller
    E500 Sorter
    E620 Editor
    HP C7280 duplex scan problem
    IN XP
    click on start and select control panel.
    in control panel on the top left hand click on switch to classic view if is not there dont worry.
    Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
    IN vista
    Click on start
    in the start search box type "printers" and click on ok.
    Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
    in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
    May 29, 2009 | HP Photosmart C7280 Laser Printer
    Hp 7680 give 'General Error, error saving file'
    There is a bug in HP firmware that doesn't allow duplex scanning to memory cards. Once it happens, you need to power down and power on the scanner. (and on a couple of occasions, I had to reformat my memory card)
    Jun 28, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Tip
    Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
    PAPER JAM A paper misfeed occurred in the
    main unit.
    Open the cover at the indicated
    location, and then remove the
    misfed paper. (“When the Message
    (Flashing alternately)
    OPEN XXX SIDE COVER
    All misfed paper was not removed
    from the main unit.
    Check the message in the display
    for the location of the paper misfeed,
    and then remove the misfed paper.
    ORIGINAL DOC.JAM A paper misfeed occurred in the
    Document Feeder.
    from the Automatic Document
    Feeder.
    Open the Document Feeder Cover
    and the Document Feeder, and then
    OPEN DOC.FEED COVER
    ∗REMOVE PAPER IN
    BYPASS TRAY∗
    Paper is loaded in the Manual
    Bypass.
    Remove the paper from the Manual
    Bypass.
    FRONT COVER OPEN The Front Cover of the main unit is
    open or not securely closed.
    Securely close the Front Cover.
    CLOSE FRONT COVER
    DUPLEX COVER OPEN The Duplex Unit Cover is open or
    Securely close the Duplex Unit
    Cover.
    CLOSE DUPLEX COVER
    DOCUMENT COVER
    OPEN
    The Document Feeder is lifted up
    (while a document is loaded into
    it).
    Securely close the Document
    Feeder.
    CLOSE DOCUMENT
    COVER
    DOC.FEED COVER OPEN The Document Feeder Cover is
    open.
    Feeder Cover.
    CLOSE DOC.FEED
    COVER
    TONER EMPTY The toner is empty. Copying and
    printing cannot be performed.
    Replace the toner bottle with a new
    one.
    SUPPLY TONER
    PAPER EMPTY The selected paper tray has run
    out of paper.
    indicates the paper tray, and
    “XXX” indicates the paper size.
    Load paper of the specified size into
    the specified paper tray.
    on Dec 18, 2009 | Office Equipment & Supplies
    HP Officejet Pro L7680 All-In-One Printer Logo
    56 people viewed this question
    Seeker5211
    Seeker5211
