Question about Vacuums
I've just installed a hoover central vaccum SH800CA and when i plug the hose in the inlet, it doesn't turn on. It turns on when I turn on the switch on the canister
  • sv_chan Sep 28, 2009
    Thanks for the suggestion.. it seems the problem is the wiring. The vacuum system was pre-wired when the house was constructed and now that the walls and basement are finished, we need to find a way to fix the wiring without breaking any walls. We added ourselves an inlet last year in the basement when we finished it and that works so we deduced it to the builders not doing a good job on the rest of the house re; the vacuum wiring. Any suggestions?
  • 430 Answers
The hose connects to a set of low voltage contacts inside the top of each inlet. The vac wiring is connected by a low voltage circuit to each inlet as well. your hose when plugged in completes the circuit when you turn the hose switch on. For simplicity ,I also use a coin to connect the terminals mentioned below instead of dragging the hose with you.
Reinsert the hose with the tongue or cord at 12 o clock or 6 o'clock position. If the vac does not start, rotate the hose cuff to 3 oclock.This over rides the hose handle switch to test the vac circuit.
if the vac still does not start you have a loss of LV signal in your wiring. You will need to back track to make sure you have continuity from the vac to each inlet.
if you have colored alarm or telephone type wire, it is very easy to break a wire strand while fastening so go back one connection at a time and inspect.
If you have no power to any inlets,your problem will be in the main run of wire from the vac, likely to the first connection. If you have power at only some inlets, your issue will be at one of your wire junctions, either at a pipe intersection or where two wires meet at an inlet, depending on how the system was wired.
Post back to say how you are making out
Posted on Sep 27, 2009
  • Chemist1961 Sep 27, 2009
  • Chemist1961 Sep 29, 2009
    When a builder roughs in a central vac, it is normally done in one of two ways, often by a sub trade not a pro installer.
    It can be wired in a series where each inlet runs with a wire heading onto the next, in which case several of your inlets will have two ore more wires,this is visible when there is only one wire at the furthest inlet from the vac but, two wires at each successive inlet heading towards the vac.
    Or you may have parallel wire runs where each of your inlets has a single wire or more running to a junction in a common area, often the basement at a pipe intersection where all wires would be spliced together.
    It is not uncommon to have missed a second wire inside a wall while attaching the first to an inlet, look for that wire at each inlet, just in case , especially if you see two wires together in more than one location. If you are running with colored wire be sure you have paired identical colors.
    It sounds as though you finished the basement and connected the final piping yourselves. Very likely at the area where you added the last inlet, you will find a matching tail of wire hanging from the basement ceiling at or near the pipe. A good installer will always run his wire against the pipe for future trouble shooting so it cannot be missed but a thoughtless one will take shortcuts diagonally to save wire, so it may be hanging nearby or tucked aside.
    The first thing you want to do is turn on at the vac itself and Quickly test each inlet for suction, then shut the vac off.
    If you have suction at each location, that means you have successfully connected all the pipes and you only need to locate the wire.If there is only a single wire at each of your main floor inlets dropping to the basement, you may be looking for more than one missed wire. This being the case you will need to return to any junction you made when connecting the final inlets and piping in the basement and look for the missing wire to tie into your wiring. If your ceiling is finished and you know the exact pipe drop location, you can cut in a speaker grille or cold air return and no one will be the wiser, but undercut your hole just to be safe.
    If you are patient and replay with detailed updates , I will gladly walk you through this step by step, but please be specific if this is ongoing as I will be checking in daily.
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
May 16, 2011 | Hoover U8145-900 Savvy Bagless Upright...
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
The Vaccum is not turning on when i plug the hose into the wall. The hoover system will turn on when i turn the switch on at the base and wont go off till i turn the switch off. But it will not come on...
you can test this out by taking a small metal spoon and with the bottom side of the spoon insert it into the vac outlet on the wall. you want to touch the two metal pins inside the vac outlet to test if the unit is the problem or the hose is the problem.
If the unit starts, the hose should have a 3 year warranty on it. I recommend you have your nearest beam dealer check it out.
If the unit does not start, it has a 7 or 10 year warranty, the circuitry should be replaced. Again have your nearest beam dealer check it out.
good luck
Nov 06, 2010 | Beam Industries Vacuums
NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Dec 31, 2008 | Hoover Windtunnel Supreme U5280-900...
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567634
Generic problem for all Vacuums
I have a 3 year
posted by patfitz on May 03, 2008
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then turn the unit on from the switch on the canister. Any help would be greatly appreciated. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that come to mind, 1st. you may have a bad switch in the hose and in most cases that can be repaired – if not you would have to purchase a new vacuum hose. 2nd. You may have a bad inlet valve in your hose and most of them are low volt of which would only cost less than $10.00 and can be replaced yourself unless you have what they call a SuperValve of which has 2 low volt wires and then it is wired to your home electricity and that should be replaced by an licensed electrician. It is a low volt and high volt inlet.
#3. the last thing you may check id that you may have a bad relay in the canister itself. Because you should be able to turn on the Central Vac with the switch on the hose and everything should work just fine . feel free to contact your local vacuum cleaner dealer in your area of call the Nutone Factory cust serv line for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://nutone.com/ Customer Service
Nutone Inc.
9825 Kenwood Road
Suite #301
Cincinnati, OH 45242
Customer Service 1-888-336-3948
Technical Support 1-888-336-6151
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Broan-NuTone CV450 Central Bagged Central...
Kenmore central vacuum system
There is two possible causes. One you could be plugging in the end of the hose wrong. Make sure the hose end is securely in and in the right position. Second it could be a malfunctioning switch in your handle. Here is a site with a variety of different hose handle switches.
www.mountaincentralvac.com
Mar 12, 2008 | Hoover F5870-900 SteamVac Vacuum
Hoover Hush Series Central Vac won't turn on
If the low voltage wires are hooked up to it, then you probably have a stuck relay inside the cannister. It could also be the switch in the hose handle.
Dec 03, 2007 | Vacuums
Central vac (Hoover) always on!
There should be a manual/auto switch. If it is in the manual mode, then it will run all the time. Other then that you probably have a stuck relay. But this will have a years warranty on it, so you should be able to have it serviced under warranty.
Oct 08, 2007 | Hoover L2310 GUV Central System Vacuum
Vacuums Logo
102 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
