Question about Garden
I have a troybilt pressure washer when i crank it up it builds pressure when i engange the pressure it takes about 5 seconds and pressure goes away if i let off the trigger it will build pressure again it only has about 20 hours of use on it (i did run a acid solution through it for my driveway wonder if that ate up a seal)
  • 148 Answers
Unloader valve is the most likely suspect here.
Remove and clean with penetrating oil then reinstall.
Also add some LIGHT oil into your supply hose via a small funnel. 3-in-1 household oil or power steering fluid lubricate the valve and pump quite well. Three or four treatments of a couple ounces each will usually make the pump happy again.
Hope this helps!
Posted on Sep 28, 2009
Will not build up pressure sounds like it is but as soon as you hit the trigger pressure goes away
Is this something new happening?
These machines quickly (a matter of seconds) build up to pressure and shut off. A slow leak is not much of a player. Eventually the pressure will bleed off and the pump come on (for a few seconds).
Pressure restored, should be good to go. Have you cleaned the inline filter to the hose. If there is a short burst of water then a dribble with a new hose, the filter is a first check
Apr 17, 2015 | Task Force 2000 PSI Electric Pressure...
020488 USER MANUAL
Contact Troy-Bilt...
http://troybilt.custhelp.com/
They have a page for Pressure Washers explaining thet tehy do not build their own pressure washers...
http://troybilt.custhelp.com/app/answers/detail/a_id/430
Jul 14, 2014 | Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure...
Building up pressure in oil pan
check if it has a PCV VALVE OR BREATHER . EITHER WAY IT APPEARS TO HAVE BLOCKAGE . EVENTUALLY THUS WILL DAMAGE THE CRANKSHAFT SEALS AND CAUSE OIL LEAKS .
Oct 28, 2013 | Garden
Troybilt pressure washer
Check the oil level. Yours may have an oil sensor switch.
May 26, 2013 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Cold start problem mazda 2001
Could be the fuel pump relay, or a faulty pump, or pressure regulator.
The fuel system is supposed to hold pressure after you turn the engine off. A faulty pump or pressure regulator could allow fuel to drain back into the tank overnight. You would need to crank the engine for several seconds to build pressure back up.
The relay could be faulty and not giving the fuel pump power until the oil pressure comes up.
Dec 08, 2012 | 2001 Mazda Protege
Troy built presure washer motor starts but seems to bind and stop when pressure builds up
More than like;ly the problem is in your valve body. Under the pressure washer. tilt the pressure washer at a 45 degree angle. On one end of the unit you should find what looks like a protrusion, (a piece of brass or chrome looks like a cap) bolted on one end of the pressure washer.
Inside the cap you will find a spring and a detent ball, this is the pressure relief mechanism. It is probaly rusted or dirty. Take it off, be careful there is usually an O ring inside the nut, dont damage it or it will leak on reassembly. Clean out the cap and the area where the ball seats.
reassemble the unit it should be fine.
If you can go on Tory's website;
http://www.troybilt-gen-pw.com/pressure_washers/
and print the owners manual, alot of them have a blow up of the valve assembly.
If not use the manual to get the name of the valve ang go to their site and get the blow up.
Good luck
Apr 20, 2012 | Garden
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
My Troybilt pressure Washer Model 020207. runs forabout 30 seconds then the motor stops. Acts like motor is locked up. Motor can't be pulled until water hose is disconnected. Took the water pump off and...
it sound like a digafame problem/or/carborater bowl has some water or needel valae is sticking cheack them if not the problem then you may have a crank shaft problem good luck see if there is oil in motor
Jan 15, 2011 | Briggs & Stratton Garden
1998 wrangler 4 cyl 110,000 miles. The engine
quite possibly it may be taking a little while to build fuel pressure. next time try cycling the key on and off 3 or 4 times with out cranking the vehicle to allow the pump to build pressure the try to star it up if it starts right up then your problem is it's just taking time to build pressure
Oct 19, 2009 | 1999 Jeep Wrangler
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
