Question about Hoover HCA331FFK
Amana bottom freezer not cold at all, all fans are running, refrigerator is only 3 years old.
  • 525 Answers
This is very simple , is compressor running?if no call the technician who can fix , if yes do the following:
Is light on when you open? Then , good news for you , your frreze is in good condition , what you have to do is to unplug it, clean the back , move it 1 foot from the wall and let it stay there . After fifteen mins , plug again. It will waork very good and don't forget to vote for me if this solution apply.
Posted on Sep 27, 2009
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Jun 27, 2011 | Amana Refrigerators
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
My freezer works but my refrigerator wont stay cold...getting warm. it is 4 years old. what could be wrong?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 26, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
Bottom freezer not staying cold
One of two things. When you open the freezer drawer, do you hear a fan running? If not, that's the problem. The Evaporator fan. Its' job is to circulate cold air throughout the entire cabinet. Without it, things get toasty. If not the Evap Fan, it'll be the sealed system... meaning that it's developed a leak and freon is escaping (not harmful for you or your Family). If it's just under 5 years old, this will be a warranty repair. Over 5? Bad news... it'll cost ALOT to have it repaired.
Jul 29, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Hoover HCA331FFK Logo
102 people viewed this question
Top Hoover Refrigerators Experts
Joseph Vernice
Joseph Vernice
Steve F
Rick Hickerson
Rick Hickerson
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
