Question about Whirlpool AWM6120 Front Load Washer
Severe vibration on spin
When my machine is on spin, it vibrates so much that it moves all across the floor. This has only started recently. It is not overloaded & it doesn't matter which cycle it's on.
  • Anonymous Aug 14, 2008
    My Whirlpool toploader GSQ9632LW0 does the same it started vibrating violently suddenly never had a problem before,its level all around,i called repairman who said he found nothing wrong, it must be sagging floor,(home 5 yrs old) he said to put paving blocks under each corner, i did this, no change, so i moved it to garage concrete floor, still vibrates without load even worse with clothes..4 yr old $600 washer, i'll never buy whirlpool again.
    Problem Solver:
  • 14 Answers
Tilt the machine back and check that the blue clips that secure the suspension legs to the base are in place and both the legs are secured top and bottom.
Posted on Dec 30, 2007
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
The tub is very wobbly and the machine was loud and moved across the floor when the spin cycle was on
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
Apr 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Jan 16, 2011 | Washing Machines
Duet Vibrates the whole house on the spin cycle. it has started this only when we recently moved.
The key statement that you made was the fact that you recently moved. Some questions you may ask yourself:
Where was your washer installed in your old home as compared to where it is installed now?
Did you re-level the feet after you moved the washer?
Did any of the shock mounts come dislodged during the move?
Is the flooring in your new home substantial enough to handle the weight and spinning action of a front loader?
The following link can give you some things to consider when trying to figure out what may be causing excessive vibration:
You may not like hearing some of this, but I can assure you, I have dealt with this problem numerous times. In the majority of cases, substantial flooring was causing the problem.
Read through the link provided and let me know if you have any questions. I hope you find the information helpful in some way.
Mar 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Vibrates and moves during spin cycle
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Dec 27, 2008 | Admiral AW22 Top Load Washer
Machine vibrates terrible on spin cylce
Mom2, sounds like you are going to need a new snubber kit. Maytag had a service flash on this, regarding vibration in spin. The snubber kit includes 6 new springs along with the snubber. This can be a bear of a job so you might want to call Maytag and inquire about SF-26-756. It should be covered. This is for model pav3200aaw, but there is a bunch of others too. It's possible that during your move the snubber became off center. If your basket is leaning to one side, you can be assured this is the back.
Feb 01, 2007 | Maytag Performa PAV3200
Whirlpool AWM6120 Front Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
