Question about CD Players
0 characters
1 Points
CD player rotates but wont play or read disc.
Cd spins but player can not play - > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) -
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc -
May 30, 2004
More results from
How to fix a boombox CD player when it wont play - YouTube
? 5:15
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | CD Players
Cannot play Walmart picture cd
You can't. Picture CDs are for computers or DVD players that are CD compatable. you can however purchase a blank DVD-R and burn the photos onto it if you have a DVD burner on your computer.
Feb 18, 2013 | CD Players
DVD stuck in machine, picture is stuck and refuses to eject by any means
Unplug the player from the wall receptical for thirty minutes, if we are lucky this will reset the microcontroller ic chip and re-initalize the system. If this fails cheaper to replace the DVD Player.
Mar 03, 2012 | LG CD Players
We have just bought a 2004 Vogue Caravan with a CD/DVD player...Philips...but there are no is wired to a system that players music in all areas of the caravan. Can you help please.
Might be connected to the actual stereo as an auxiliary item so the caravan stereo may have to be turned on and set to auxiliary in order to hear the surround sound.
Mar 02, 2011 | Philips CD Players
No picture
There is no problem here as CD players are audio only, no picture is designed to come out of them . The big clue is on the back, there is only red and white audio outputs. There is no scart, rgb, composite or other tpye of video connecter output.
Jan 07, 2011 | CD Players
While playing dvd get sound but no picture-nad dvd player m-55
are you switched to AV2 on your tv/monitor??
Sep 27, 2009 | NAD CD Players
Have video w/an S-cable, but can't get sound w/the optical cable
s video is only for video so run an extra set of red and whit rca cables for sound
Mar 15, 2009 | CD Players
While connected via VGA cable Viewsonic VG920 Monitor has an error stating "out of Range" . H. Frequency 157 Khz V. Frequency 59.8 Khz
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
Dec 13, 2008 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
Curtis DVD Player
Hi Kathy, The DVD player has accidently set to the wrong video ouput or P.Scan mode. Remove the disc from the DVD tray and press the P.Scan button on the DVD remote control untill the pictures comes back. You should receive the picture within three clicks on the P.Scan button. Thanks, Mike
Nov 02, 2008 | CD Players
Code for Goldstar CD-DVD player - DV4221NC
CD's will not play. System comes on fine, all connections are good, but CD's will not turn or play. I can advance the CD's but no sound. Speakers are good and received is on CD/DVD.
Jul 05, 2008 | CD Players
CD Players Logo
524 people viewed this question
Top CD Players Experts
Dave Jukebox
Are you a CD Player Expert? Answer questions, earn points and help others
