Question about Lexmark X83 All-In-One InkJet Printer
Color cartridge not working even thou it's a new lexmark cartridge
SOURCE: color cartridge won't print/ black and white is fine
Hi Franelyn !!
giving u some steps so that you get anser to ur question that why your color ink cartrideg is not workign
It might be beacuse of faulty printheads of printer or fauly printheads of cartridge
To check which one is faulty : take a tissue or cloth ...slightly moistened it with water an dtry to clean nozzles of cartridg and observe that some ink is coming out from cartridge or not , if not shake the cartrideg again clean its nozzles , if still no ink comes out that will ensure that the cartride is bad
Posted on Dec 07, 2007
SOURCE: Lexmark 2500
me too.
Posted on Apr 04, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
Ajkill
  • 2035 Answers
SOURCE: lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 31, 2009
  • 62 Answers
SOURCE: My lexmak 5140 will no read the color cartridge.
Hello
You can go to that website and check the link.You are going to get the resolution.
http://www.product-reviews.net/review/20081128/lexmark-x5410-printer/
Thanks
Posted on Apr 04, 2009
Is it true that both my new Lexmark Prevail Pro 705 print heads quit printing in color is because I didn't use Lexmark OEM ink cartridges?
Some Lexmark cartridges have an RF chip mounted underneath the label on top. Most of these are set to self destruct on first use to prevent refilling. You probably need to risk the cost of a new cartridge to find out if it is a cartridge problem or a printer problem. Unfortunately you should not take out a cartridge or replace one while the machine is powered. The system also frequently registers an serial number on the cartridge and stores it to prevent "hot swapping" cartridges
Dec 11, 2017 | Lexmark Prevail Pro705 Wireless AIO...
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
My lexmark 3150 printer will not print anything in color even though the refill color cartridge is completely full
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. But if that doesn't help, I would suggest that you replace it with new genuine Lexmark cartridges.
Aug 26, 2011 | Lexmark P3150 All-In-One InkJet Printer
Missing color ink problem
no- the printer/fax has to detect both cartridges, even if you use an empty cartridge in the color slot.
Sep 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Just replaced my black and color cartridges with new lexmark...
Hi tfonts,
This is normal behavior for proprietary print devices if you have not provided them with a new print cartridge and have instead filled them yourself.
Terry
May 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
I installed a new "genuine" Lexmark color ink cartridge, but it doesn't work.
then get it replaced by lexmark as the cartridges comes with one year warranty..
Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Color
Sometimes even a new Cartridge is bad depending on how long it was sitting on the Shelf. I would try a new cartridge. i f that works, return the bad one.
Feb 12, 2008 | Office Equipment & Supplies
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Lexmark X83 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
