Question about Samsung Refrigerators
Water accumulation underneath the bottom vetable
Water accumulation underneath the bottom vegetable bin
    Scholar:
  • 150 Answers
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Posted on Sep 27, 2009
Why do water accumulate at the bottom of my fridge under the vegetable tray?
If your refrigerator is frost-free, the water accumulates during the defrost cycle and should drain through a tube at the bottom into the evaporator pan underneath. The tube may be clogged or broken.
Dec 18, 2014 | Refrigerators
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Water accumulating on refrigerator bottom under vegetable pans
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | Refrigerators
Water accumulates under vegetable bin (bottom of refrigerator) every couple of days
If this is an older style top mount refrigerator than most likely the drain is clogged causing the water to leak into the fridge during the defrost process. What's the model number?
Jul 06, 2011 | Refrigerators
Water accumulating in vegetable bin on model
This is caused by a clogged drain tube or the door is not closing correctly. Be sure the seal around the fridge door is closing correctly. If not, the drain tube needs to be replaced or cleaned.
Nov 06, 2009 | Admiral Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
398 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
