Question about Samsung NV4 Digital Camera
The problem is when i switch my camera on, on the display is says turn off and on again. i have done this repeatedly with no affect. how can i fix this?
2 Suggested Answers
SOURCE: the problem is when i switch my camera on, on the
ok so I was searching for the answer for this myself.. very hard to say, because it really depends on what happened to your camera.. Did you drop it? Did it emerge in water? But for me, I have come to the conclusion for everyone who has the problem.. it is most (99%) probably a problem with the lense.. another site told me to take it to get fiixed- or to take the battery out and wait 20 min to put it back in, because this resets it. I decided to manually open the lense myself (who knows if thats bad/good to do, but a girl's gotta take her pix!!) So anyway, i opened the lense, and turned it on- the "on again off again" msg went away. So most likely, the problem does stem to the lense not being able to be opened, so the msg pops up, if you open the lense yourself your camera works fine, when you turn it off- my closes the lense-just doesnt open it. different results for different people, but i hope this helps because it was very simple.
Posted on May 02, 2010
My Sony DSC-S60 camera lens in stuck open and my camera is stuck on access. It tells me turn off camera then back on. I have done that several times with no luck
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Sep 10, 2011 | Sony Cyber-Shot DSC-S60 Digital Camera
MY Sony cyber shot DSC W35 camera's shutter is open and close repeatedly and asks for power off and restart but nothing is happening. PL advise
Turn on the camera.
To reset the Camera, press the RESET button located inside the Jack cover of the Camera using a sharp pointed object like ball pen or paper clip. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Jul 17, 2011 | Sony Cyber-Shot DSC-P52 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Feb 04, 2010 | Samsung NV4 Digital Camera
Sony Cyber-Shot camera problems
I read that if you bang the camera against your hand a couple of times it can fix it. I tried it and it fixed it until i turned the camera off and on again. Tell me how it works for you.
Mar 23, 2008 | Cameras
Repair of Camera digital Panasonic DMC TZ3
See if helping the lense to extend will prevent this message.
Feb 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Oct 16, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Problem - Turn off and turn on again - happens repeatedly
We see this camera often because the lens gets compressed some how and the plastic gears which drive it become damaged, this would be the "buzzing" noise you're hearing during power up. The camera is not passing its power up diagnostics and therefore it shuts down. The lens is not cost effective to replace on this camera, parts and labor exceed a replacement units cost. Hope this is some help. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Oct 04, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
After switching on - the lens extends and retracts repeatedly
I had the same issue and thought me Ebay camera was trash. I put the batteries back on the charger over night and it worked properly in the morning. Looked to be a low power issue, but my lens did look like it was all cocked, grinding and stalling. perhaps the camera reset itself with no batteries in it for a few hours> I was very relieved.
Jun 13, 2006 | Olympus Camedia C-5050 Zoom Digital Camera
Samsung NV4 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
