Question about HP OfficeJet 7410 All-In-One InkJet Printer
Remove and check cartridge on right
I have an HP officejet 7400 all in one.I keep getting error message "remove and check cartridge on right". I have replaced/cleaned the cartridge and the contacts on the printer. Any ideas?
SOURCE: HP Officejet 5600 All-in-One series
I had the same problem. It said I had a problem with the right cartridge even though I put a fresh HP 27 in there.
Even though I put a new black 27 in and my color 22 still had ink in it, I removed the color 22, left it print without the color in it by changing the settings to printing greyscale, black cartridge only. Then I put a fresh color in it as well, changed the settings back to color, now it works fine. Maybe all I needed to do was put a fresh color in it even though it didn't need it. You can try that as well.
Posted on Dec 16, 2007
Metawatch
  • 96 Answers
SOURCE: Right print cartridge issue
Some 3rd party cartridges are not perfectly manufactured and in many cases you'll need to press firmly (not hard) on the top front of the cartridge to ensure adequated contact is made wih the electronics on the cartridge and your printer.
Posted on Feb 10, 2008
  • 327 Answers
SOURCE: remove and check color cartridge
the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Posted on Dec 15, 2008
  • 10406 Answers
SOURCE: Error message HP Officejet 7310
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Posted on Nov 25, 2009
SOURCE: Cartridge Error message - I've cleaned the
I have same exact issue. Please contact me if you get answer.
Posted on May 11, 2010
I have a 7300/7400 HP Office Jet printer....keeps giving false alarms on paper jam. I have done everything the book says. The print cartridges do not return to the right. I love this printer and
there are a few sensors in the paper circuit. if those sensors have some small pieces of paper you will continue to get this error. If you have serious mechanical skills you can try to disassemble the printer and clean every sensor. if not you should go to a specialized service center.
Jan 17, 2012 | HP OfficeJet 7310 All-In-One InkJet...
I am getting an error message remove and check right cartridge?
Replace the right cartridge with a new genuine HP cartridge.(not a re-fill)
If still does it check that the contacts are clean where the cartridge seats.(wipe with a q-tip)
Aug 31, 2010 | HP Officejet 7210 All-In-One InkJet...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Receiving a "Insert color cartridge" error message
You hit it! Go out and buy a new cartridge. Most likely you got a bad one.
Jun 19, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hi i hace HP Photosmart C4188 All-in-One Printer and since last few days i am facing a problem "Remove and check crtridge on right"
the right side cartridge is gone faulty and needs replacement so this error message.just follow the message and replace the cartridge.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Dec 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Feb 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Repeated error message
Very Simple, Probably...
Just remove the cartridge and see if the metal spring clip has broken away from the right wall. If it has, inspect the gold colored circuit board at the back of the cartridge bay...there is probably a hole or dent where the clip slammed into it.
If you have these symptoms, go to HP, and go to the chat support window, describe your problem, and they will send you a replacement printer.
It's exactly what I did.
Jan 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
208 people viewed this question
Seeker5211
Seeker5211
