Question about Compaq Evo N610C Notebook
Left click and touchpad click not working
Left click and touchpad is not working.where can i find any option for adjusting the settings to let my touchpad work properly.
  • Compaq Master
  • 8,404 Answers
Look in your control panel for the device settings
Posted on Sep 27, 2009
Unlock scroll key
Toshiba laptop computers use multi-function touchpads, which often have software features added to the touchpad manufacturer's basic package. If your Toshiba laptop's touchpad won't scroll but its other functions are working, you may simply need to adjust your settings. If the problem occurs suddenly, try restarting your computer before resorting to other methods. Sometimes the addition of new software or other features can interfere temporarily with the touchpad driver, interrupting the scrolling feature. If a simple restart does not restore your touchpad's scrolling feature, check its properties through the control panel. The exact options for doing so will vary by laptop model and operating system.
Click "Start," then "Control Panel." Navigate to "Mouse," which may be under "Hardware and sound" or a similar category, depending on your operating system. Select the "Touchpad" tab in the "Mouse" window. This tab will also list the touchpad manufacturer, most often Synaptics on Toshiba computers. If you have more than one built-in pointing device, as is the case with the touchscreen model Toshiba Portege series, choose the "Hardware" tab and select your touchpad, then click "Settings." Select "Properties," "Settings," "Advanced" or the similar option on your system. Click the box next to "Enable scrolling" if this option is available. For Synaptics touchpads, you may have a list of options; click the arrow to the right of "Scrolling" to open the scrolling list and select one-finger or two-finger scrolling to access the specific features. Click to enable any scrolling features you desire, then select "Adjust scrolling region" or the similar option, if available. Drag the scrolling region to cover a larger portion of the touchpad if you want to ensure you can scroll easily. Click "Ok" to apply any changes and close the options windows. Keep clicking "Ok" until all of the windows with this option are closed. Restart your computer if prompted. Your scrolling feature should be enabled.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuaserguides-su1083054-SatM50M55PMAD0004401105May05pdf&sliceId=pdfPage_171&dialogID=79031610&stateId=0%200%20
Feb 18, 2013 | Toshiba Satellite L305D-S5895 Notebook
Tip
Dell Latitude Portable (2008 or newer) has jumpy cursor when typing
The Touchpad driver setup has options to keep the cursor from jumping while typing.
  1. Open the Touchpad Properties
  2. Touchpad Settings
  3. Enable the TouchCheck option, set the slider to minimum. (TouchCheck disabled the touchpad while typing. The Slider adjusts the delay. Minimum is .5 second delay, and each notch and additional .5 second delay)
Other options that may cause user problems are Draglock and Tap to Click under Touchpad Settings, and Scrolling and Zoom Settings of Touchpad Properties.
on Jul 12, 2010 | Computers & Internet
Left click will not work
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar . Or disconnect the mouse from your computer restart.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Hope this helps.
Jan 23, 2013 | Toshiba Satellite C655-S5123
Sencitivity of touch pad how to adjust
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad. Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Change Touchpad Settings in Windows1. Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
2. Double-click the Control Panel's "Mouse" icon.
  • 3. Click the Touchpad tab. This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers. However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings. Refer to the "Warnings" section if this applies to your computer.
  • 4. Locate the "Scrolling Settings" area within the touchpad properties tab. Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes.
  • for MAC OS
  • Click the Apple menu and then select "Preferences."
  • 2
    Click the "Keyboard & Mouse" icon.
  • 3
    Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
  • 4
    Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
  • Dec 01, 2011 | Computers & Internet
    How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
    1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
    2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
    3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
    4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
    5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
    Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
    My cursor moves as i type what can i do
    You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
    Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
    Jan 01, 2011 | Computers & Internet
    Hi! I have compaq 610; win 7. the touchpad click option is not working.
    you probably have to change the current settings.
    In most cases the settings for the mouse can be selected with the icon in the right of the taskbar, to the left of the clock.
    It should have a setting for click on the touchpad.
    If this option is not available, try the adjusting the settings from control panel >> Hardware and sound >> Mouse.
    If it still does not work, try updating mouse drivers from manufacturers website.
    Sep 21, 2010 | Compaq Computers & Internet
    I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
    Hello cskpuels,
    It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
    •Tap once on the main touchpad for single click.
    •Tap twice for double click.
    •The lighter the touch, the better the response.
    •Tapping harder will not increase the touchpad's responsiveness.
    •Opening the Control Panel
    The Windows Control Panel can be opened by:
    Selecting *Start > Control Panel (on Windows Vista)
    - OR -
    Start > Run > Type 'Control' and select OK (on Windows XP)
    *The Enter key may be used on the keyboard in place of touchpad clicking*
    In the Control Panel, do the following:
    •Select Mouse [Enter] (Brings up the touchpad properties sheet)
    •Look at the Buttons tab in the touchpad properties sheet.
    •Adjust the settings and test the touchpad until you get the response you desire.
    If this solution is helpful please click 'YES' by 'Was this helpful?' below.
    Have a great day,
    martyshaw152
    Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
    Mouse touchpad, keyboard, and usb drives will not work
    One thing you can try (for the touchpad)
    Acer have got a function key to turn it on and iff (i thought mine was broken for a year). Hold the function key, which is located bottom left of keyboard, and then press F7. It should be F7 anyway.
    Hope that helps for your touchpad
    May 05, 2008 | Acer Aspire 3000 Notebook
    "sticky" mouse on compaq laptop
    Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
    To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
    Regards,
    Javabytes
    Nov 07, 2007 | HP Compaq Presario V2000 Notebook
    Compaq Evo N610C Notebook Logo
    291 people viewed this question
    Top Compaq Computers & Internet Experts
    Abhinandan  Patil
    Abhinandan Patil
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
