Question about RCA Universal Remote Control
Universal remote The universal remote I got will not do a timed taping on any channel except 3. I can navigate all channels in either t.v. or vcr mode. But when it comes to doing a timed taping it seems to be set for 3 and nothing I do can get it into channel selection. the vcr is a rca #vr546/vr687hf that worked with no problem withmy previous universal remote. The remote I now have is a rca311b1
    Genius:
  • 1,694 Answers
Consult VCR operator manual .....If I remember,there is a selection in the menu to designate a channel so that when a source box is used, the channel selected remains the same in
timer mode........channel recorded is selected on box,in that
equipment configuration............so step thru the video recorder
menu on page at a time.........T.
Posted on Jan 02, 2008
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Lost remote mrd 310
most universals will use this method.
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 29, 2008 | Philips Magnavox Learning Universal Remote
I need the code to program the philips universal remote to a sylvania tv
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Need codes for philips remote control SRU4208WM/17
the process is similar
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Need VCR codes for Magnavox Universal remote model CL034
Nov 26, 2008 | Philips Magnavox Learning Universal Remote
I need the universal remote code
Remote code
1. programed RCVR with code 0314
2. then assigned a key (such as the TV/VCR key) with the EFC number of 300
3. then reprogramed RCVR w/ code 0027
498 "surround mode"
568 "+10"
578 "band"
370 "stereo"
702 "6"
444 "4"
447 "2"
317 "8"
701 "0" (zero)
450 "7"
704 "5"
707 "3"
449 "1"
577 "9"
384 "tape 2"
252 "mute"
255 "vol down"
512 "power"
515 "vol up"
572 "channel down"
257 "channel up"
Try This an see if works
Oct 19, 2008 | Kenwood VR-209 Receiver
Set up for channel 3 on 27gt616
for watching video tape select a/v mode and connect audio & video wire from vcr to tv
Sep 28, 2007 | GE 27GT616 27" TV
Televison & Video Logo
156 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
