Question about Canon PowerShot SD960 IS Digital Camera
Cannot see image in viewfinder
The camera will turn on, I can record but only sound, no picture. The camera appears to be taking a picture but the viewfinder is completely black. Nothing happened, did not drop camera, nothing.
SOURCE: Viewfinder
There's a little scrolling wheel to the left of the viewfinder; move it up or down until the image is clearest.
Posted on Jun 03, 2007
SOURCE: No image in viewfinder or on screen
Well kids, I sent an e-mail to Canon linking this page. This is clearly a Canon problem and we paid enough for our cameras that if this is as common a problem as it appears, they should be fixing it at no cost to us.
I can tell you are as frustrated as I am.
I would encourage all of you to e-mail Canon if you have not done so already.
Posted on Nov 02, 2008
t00nz
  • 4738 Answers
SOURCE: Powershot s500: viewing screen is black. It won't take pictures.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jan 04, 2009
t00nz
  • 4738 Answers
SOURCE: Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 14, 2009
  • 85 Answers
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Posted on Jul 08, 2010
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
I want to move my picture to the right. About 1/4 of a person or writing is not viewable on the left side of the picture
If the photo has already been taken, and the area to the left has not been recorded, then there is no way that the missing part of the image can be restored. If, however, you notice the area is not in the viewfinder prior to taking the photograph, the solution is simple - re-frame the image, so that all of the subject appears in the viewfinder. If necessary, step back a pace or two (being mindful of any obstructions or other dangers behind you) until the viewfinder shows all that you wish to record. It is better to leave an area surrounding the subject, which can be removed in pp exercise, than to crop detail at the taking stage.
If the problem occurs when you are printing images, ensure that your image-editing software is set up to display the entire image, and that you are not inadvertently cropping it.
Nov 29, 2016 | Cameras
Canon Power Shot A560-My camera will allow me to see images when recording video, but I cannot see images when I want to take a picture. The screen is completely black. Not sure what happened. It has...
Sounds like you just accidentally pressed the DISP or DISPLAY button on the back of your camera. This turns the screen on and off in photo mode to save batteries (you'd then use the optical viewfinder in its place). Just press the button one more time with the camera turned on.
Jun 17, 2011 | Canon PowerShot A560 Digital Camera
My d40 has a image in viewfinder, will not take picture
It sounds to me that you are using an incompatible lens or a broken one. Does this happen with the lens that came with the camera?
Feb 14, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Scrambled LCD Screen
I think its problem of bad ccd imager or some any connector is lose in your camera.
Let me know exact model number to help you more.
Dec 19, 2008 | JVC GR-SXM260U Camcorder
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Records sound but no picture
there are two possible problem of your camera...one check the iris of the camera if it is opening,you will see it went you look inside the lens when you turn on camera mode....and if you see that the iris is opening...the second may be the ccd image sensor......if that is the problem you have no choice but to go the sony service for replacing the ccd image sensor...
Sep 03, 2006 | Sony Handycam CCD-TRV37 Camcorder
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Canon PowerShot SD960 IS Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
