Question about Craftsman Garden
My pull cord on my craftsman mower broke and I bought a new cord but cant get the pulley cover off to replace it, how do you do it?
If you have the same model a I do, it has rivets not screws, and I suspect the entire motor cover must be remove (machine bolts at front and beneath the gas tank) the retaining ring hex bolts at top releases the gas tank which can be tilted out of the way
Posted on Oct 15, 2013
    Problem Solver:
  • 6 Answers
With all the side screws removed it should come right off. There will be a little resistance, but that's normal.
Posted on Oct 01, 2009
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Craftsman 917-377150, the pull cord broke and the housing to replace it is rivited in place, can I drill these out, but then what?
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Jul 30, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
How do I replace the pull cord on a craftsman 6.75 HP EZ walk?
Remove the three or four bolts holding on the pull cover and lift it off the mower.
Get a length of new pull cord and fish it into the hole the cord comes out of while passing it into the cord reel underneath the cover. There should be a hole in the reel where you can see where the cord should come out. Then you tie a knot into that end of the cord. With the cord now on the reel you wind it backwards with free end of the cable enough turns to **** in the free cord when you let it go. Usually 6-10 turns minimum. Remember to allow for the distance to the lawn mower handle! Unless your cord terminates at the top of the pull cover.
Good luck and be careful!
Oct 04, 2010 | Craftsman Garden
How to install pull rope on Craftsman 917.37717 lawn mower
First, this is best done with two people, unless you have 4 hands. Second, with rope pull cover off the mower and laying on table with rope pulley up so you can see it, remove all the old rope. Next, measure 8 foot of new rope.
Now, line up the holes where rope will go thru the cover and into pulley, now with someone holding the cover, rotate rope pulley 6 complete turns, now hold pulley there, while putting new rope thru the rope openings in rope pulley and outer cover. Tie knot on end by rope pulley and have who ever was holding cover and other end of rope, slowly release the rope so it rewinds, install rope handle and walla, your done. 5 minute job, depending on how much coffee you drink. Hope this helped you.
May 28, 2010 | Craftsman Garden
Lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
May 04, 2010 | Mtd 22" Yard Machine Push Mower
Pull cord broke on my lawn boy mower,new cord won't retract??
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 16, 2009 | Garden
Pull start rope broke
You have to remove the whole cover. Do not break rivets. Remove the rest of old rope, then wind pulley/spring the direction it would turn if the rope was being pulled. When it's wound tight, back off to align hole in cover and pulley. Insert end of about an 8' rope from the outside the cover through the pulley and tie a single knot/loop. Then let the rope be drawn in by the pulley/spring.
Jun 20, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Garden Logo
363 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
