Will my RCA Universal remote work for a Durabrand Surround Sound System?If so how do i get codes?
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
SOURCE: Codes for Universal remote for a Durabrand speaker system
You will need the manual. Probably have to hold Menu or a combination of buttons for a couple seconds and punch in the appropriate code for your device. You can find just about any manual online...just google everything you know about the remote and look for a manual pdf or something. Good luck!
SOURCE: Broken Remote
yah! you are correct. The thing you do and for sure is to buy another remote from the company.
SOURCE: Lost code sheet for RCA remote RCR450C; Durabrand TV DU 1901
CUALES SON LOS CODIGOS PARA UNA TELEVISON CELERA DE UN CONTROL RCR450C?
The easiest thing to do would be to go to an electronics store, look on the back of the remote control package and look for Durabrand.
It should come with a booklet with the setup codes.
Thats all I got for now.
Hope that helped, good lukc, please rate.
