Question about Nikon COOLPIX S710 Digital Camera
I was taking pictures earlier and my nikon s710 just went dead. The lens is still out, didnt go back in like it does when it is turned off. I have tried charging the battery, but no joy. Please help
Camera lens went blank, will not turn off, no buttons work
Suspect dead battery. Charge os replace. Then turn off and back on.
Apr 14, 2014 | Nikon COOLPIX S3300
I was using my Nikon coolpix s205. after taking pictures, it went on standby mode and when i was going to use it again, the monitor was just black and i cannot take pictures anymore. i tried to turn it off...
All I can suggest is 1) Fully charge the camera. and 2) Make sure NO cable is attached to the camera when you turn it on.
Background; Lens motors use lots of power and with a dead battery they do not work very well (stuck) When you have a cable attached to the camera the monitor WILL shut OFF.
May 02, 2017 | Nikon S205 Digital Camera
My battery has went dead and when I went to charge it. It wouldnt charge at all. Plus, when it was working and I would go to take pictures, it would sound as if something was loose in the lens.
If your Nikon EN-EL10 battery for your Coolpix S4000 won't be charged, there seems something wrong with your battery or battery charger, so you need a new one. The problem about lens, if something was loose, there maybe a screw and after a term it may cause lens error.
Feb 08, 2011 | Nikon Coolpix S4000 Digital Camera
My Nikon coolpix S710 has suddenly come up with 'Memory card is write protected and wont take pictures now. Does anyone know how to fix it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 18, 2010 | Nikon COOLPIX S710 Digital Camera
Nikon s710 pictures captured look yellow and darker than usual
Can the white balance have been changed accidently?
This will make the pictures look yellow.
So will taking pictures indoors under artificial light.
The White Balance setting is under the shooting menu, try setting it to auto.
Hope this helps.
Feb 25, 2010 | Nikon COOLPIX S710 Digital Camera
Nikon coolpix s710 focusing problem
the lens may be dirty. try replacing the batteries and taking an alcohol dipped q-tip to the lens.
Mar 15, 2009 | Nikon COOLPIX S710 Digital Camera
Lens error on nikon coolpix S 710
Sometimes if you are barely touching or blocking the lens when it tries to extract, it will say lens error. You'll need to turn it off and then turn it back on. It's kinda of like a safe mode for the machanics so it doesn't break.
Jan 11, 2009 | Nikon COOLPIX S710 Digital Camera
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Nikon COOLPIX S710 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
