Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
No water entering washer . - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 61 Answers
Make sure water is turned on check water inlet valve
Posted on Sep 28, 2009
  • 6,784 Answers
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the washer is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
NOTE-If the inlet is functioning correctly, this will confirm that the control is the issue. replace the timer or control board asap in this case.
Posted on Sep 27, 2009
Water not entering washer at start of cycle
check to make sure water is on if so then turn off all water and disconnect water hoses from back of washer, clean the screens that filter the water entering the washer
Aug 17, 2015 | Washing Machines
Frigidaire front load washer starts the cycle but no water enters the washer
Hello friend, I appreciate your post!
Based off the information you have provided water is not entering your Frigidaire washer. Are the house valves turned on fully? Check to make sure that the house valves are turned on and if they are check to make sure the water hoses are not kinked or pinched.
The problem could be within your water pressure, pressure switch, or water inlet valve. I would recommend reaching out to a professional for further assistance regarding your washer to avoid any unnecessary part purchases. I hope this has been beneficial. -Matt
Oct 12, 2014 | Frigidaire Washing Machines
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
Whirlpool ghw9150pwo flashes FH
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Oct 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps flashing up fh and not working
GENE
Oct 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an HF reading on my front load washer, water is going in and out. What could be the problem?
GENE
Sep 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 12, 2010 | Miele G892SC SS Dishwasher
No warm or hot water entering washer
Clean inlet filters for water supply hoses coming into back of washer. There two small screens on the inlet fittings, "back of washer" that must be removed and cleaned once yearly.
May 28, 2009 | Maytag Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal De
