Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
My Moultrie 140 Camera does not take pictures in the field. When I run diagnostics I get the error code 020000. Can you tell me what is wrong?
  • Moultrie Expert
  • 296 Answers
Flash error....try removing bats with power on; turn power off; reinstall bats; turn power back on...run system diagnosis...FOLLOW SCREEN INSTUCTIONS
Posted on Feb 17, 2010
Diagnostic error 2000
Moultrie liebherr diagnostic Digital Cameras Questions ...
www.fixya.com > Forum > Tags > liebherr diagnostic > Digital Cameras
Moultrie digital cameras liebherr diagnostic related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
moultrie diagnostic test error 000480 Digital Cameras ...
www.fixya.com > Forum > Tags > moultrie diagnostic test error 000480
Digital Cameras moultrie diagnostic test error 000480 questions and answers. Ask your moultrie ... ...moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Moultrie diagnostic code 12 Digital Cameras Questions ...
www.fixya.com > Forum > Tags > diagnostic code 12 > Digital Cameras
Moultrie digital cameras diagnostic code 12 related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Jan 20, 2016 | Cameras
Moultrie i40 digital game camera will not flash
run diagnostic test and cover sensors with thumb...may have to shade IR flash array to see it glow red...menu may start countdown...if flash doesn't glow you will get a 020000 error(flash/flash charging error).To fix you need to remove batteries,sd card,rubber plug from remote slot, 5 screws from face;lift out face and turn over. Remove 4 screws, keeping separate from other screws, from camera card and carefully unplug (3 plugin connectors) and carefully lift camera card out..no soldering required up to now..2 conductors,a red and a black, connect to the flash array at one corner...these go to the sensors on the face,slightly under main board...either the sensors are bad or the array is bad...getting replacements is the problem unless you can get them...I buy "as is" cams off eBay.
Dec 14, 2011 | Moultrie I40xt I40xt Trail Camera 50 Mp
Got error code 020000
Error code 020000= flash/flash charging test failed...the IR array or the day/night sensor is bad...I get my parts from other defect cameras...Moultrie charges $25+ S&H to tell you to buy new camera.
Nov 08, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie game cam error code 1496 ?
this can't be an error code; error codes are in the format of 000000...100000=bat.test(0=pass;1=failed);020000=flash test/charging(0=pass;2=fail);003000=IR Sensor Test(0=pass;3=fail);000400=Camera Mod Test(0=pass;4-fail);000050=Memory Test.In this digit there are several codes...(0=memory ok/no sd card;5=memory full;6=SDcard locked;7=SDcard damaged;8= comms error)last digit,000006=Clock Test(0=pass;9=fail).
Are you sure this # is not preceeded by an "E", WOULD BE # OF EVENTS SINCE THEY WERE LAST CLEARED.
Ron L.
Jan 15, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie i 40 showing error 020000
this is flash test fail....cover sensors when performing system ck.
Dec 11, 2009 | Moultrie MFH-DGS-100 Digital Camera
Error code 020000
power on;remove bats;power off;replace bats...if 020000 still there, need to replace IR LED ARRAY.
Oct 10, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie gamespyi40 error code 020000
I just spoke to the moultrie techy about the same error message I have with my i40, This is a false positive message, the i40 uses infra red instead of a flash; the self test is testing for flash and giving the false error. This was an oversight by Moultrie, no down-loadable patches are available to correct this at this time
Joseph
joseph@isportingworld.com
Jan 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moutlrie I-40 IR flash doesn't seem to work
error 020000 relates to flash/flash charging...if new, take it back.I have repaired several by replacing the IR LED flash...easier fix than the incandescent units.
Nov 09, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
644 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
