Question about Estate EED4300SQ Dryer
Quickest way to gas valve
Lloks like i need to replace my gas valuve coils. whats the quickest wat to get to it... do i have to take the whole dryer apart??
  • 833 Answers
The quickest and safest way is to call someone in who knows how to do this. Gas explodes. The gas manifold is located under the top panel, generally.
Posted on Dec 21, 2007
Samsung gas dryer gas valve coils
Go to www.repairclinic.com and enter the model of your Samsung gas dryer. You will be presented with a list of common repair parts and may be able to view a video showing disassembly of a typical Samsung dryer. You also can get a straight answer regarding replacement.
Jul 14, 2016 | Whirlpool Dryers
GE profile dryer Pilot lights on but not the whole burner
the pilot your seeing is the ignitor the gas valve coils are probably bad these are mounted on top of the gas supply valve on the burner tube,you need to unplug the unit and remove the top and front cover to access the valve and coils,there are 2 screws securing the gas coil valves onto the gas valve remove these and remove the bracket,unplug the coils and reverse to re assemble the unit
Feb 21, 2013 | GE Profile Prodigy DPSR513GA Dryer
MY husband replaced coils on top of gas valve. He
is it completely dead now or does some things still operate??? and what make is the dryer?
Oct 05, 2009 | Dryers
My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Sep 17, 2009 | Amana ALG331RAW Gas Dryer
Dryer flame turns off after a couple of minutes leaves clothes damp
HI, this is the result of a faulty set of gas valve coils.(black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
There are also a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance as well. Replace the defective thermostat.
Jul 19, 2009 | Dryers
Dryer ignites but does'nt light
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jul 13, 2009 | Amana NGD7200TW Gas Dryer
The gas stops after 15 seconds
Hi. The problem is with a set of defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective. They are responsible for the valve actions. if these solenoid based devices start to malfunction, this will heel the gas flow and, cause erratic behavior during the cycle(no flame).
Replacing the coils will fix this issue.
Jul 09, 2009 | Whirlpool WGD6200S Gas Dryer
Kenmore 74812 Gas Dryer. Was told it ignites,
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Jun 22, 2009 | Kenmore 74812 Gas Dryer
Electric egnitor for a gas dryer lights but does not stay on
Check the following-
Gas valve coils
Jun 03, 2009 | GE Dryers
Hotpoint gas dryer still wont heat
see if voltage to gas valve if none bad board if ok bad gas valve
Sep 05, 2017 | Dryers
Estate EED4300SQ Dryer Logo
Top Estate Dryers Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Mike
Are you an Estate Dryer Expert? Answer questions, earn points and help others
