Question about HP Photosmart 2710 All-In-One InkJet Printer
All lights are flashing
Reload drivers - works for a short while - then stops working and all lights start flashing - happens repeatedly??
  • barryzina197 Sep 27, 2009
    where is my 'free' answer??
  • 863 Answers
Quit reloading same driver and look for new updated drivers that will run on your operating system.
Try reverting back to your old operating system if you recently upgraded to the new operating system.
Posted on Oct 26, 2009
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
Engine stops while driving,will not start or stay running for hours,only to die again in short time replaced fuiel pump pcv valve,fuel filter
Do not replace any further components until you have your On-board diagnostic (OBD2) codes read.
Your vehicle is fitted with a sophisticated OBD computer which monitors the performance of all engine emmission sensors and components.
By jumping pins 5 & 6 of your datalink connector (DLC connector located under dash, above driver's knee), your Engine Check light will flash the codes present stored in memory.
  1. Run the engine until it reaches operating temperature, then turn engine OFF.
  2. Using a thin jumper wire (speaker wire will do), join pins 5 & 6 (note this connector may be upside down).
  3. Turn ignition key to ON (do not run engine) - the Engine Check light should start flashing.
  4. The 1st group of flashes is the 1st digit of the code; (short pause), 2nd group of flashes is the 2nd digit of the code (short pause) and so on. Note: codes will be separated by a long pause. E.g. Flash, Flash, Flash (short pause), Flash, Flash (short pause); Flash, Flash, Flash denotes: Code 323 etc
  5. Codes will usually repeat - turn key to OFF, once codes have been correctly read.
If the above procedure works for you, please post your codes on here and one of us will assist you with further diagnosis.
Cheers,
Aug 27, 2011 | 1997 Chevrolet Camaro
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
WINDOWS LOGO APPEARS WILL NOT LOAD UP FLASHES BLUE THEN TRIES TO RELOAD BUT JUST KEEPS ON REPEATING ITSELF. PLEASE HELP
unplug all external devices then try
It is having a critical error on start up so most likely a driver issue; hit f5 as it starts repeatedly and then select start with last known good configuration and see if this works.
If not do the same but sselect safe mode. In safe mode go to restore and select a day when it started with no hassle.
If all else fails you may have to repair or reinstall using windows disc
Jan 12, 2010 | ASUS Eee PC 900 Notebook
Dell vostro 1510 error lights
But the Diagnostic indications says exactly that you needs a Motherboard replacement
Jan 05, 2010 | Dell Vostro 1510 Laptop
My parking break light flashes 6 short, 1 long and repeats...any clue? 89 chevrolet silverado 5.7L 700R4 2wd
6 short flashes seperated by one long flash indicates an erratic speed signal with the rear wheel antilock system. after performing any repairs, with key turned off, pull the stop/hazard fuse for 5 seconds to clear codes. the speed sensor is located towards the rear of the transmission on the driver's side
Jun 20, 2009 | Chevrolet C1500 Cars & Trucks
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Adapter stopped working
I have had a D-link wireless adaptor that has worked for years. I would say the device was faulty.
May 29, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
HP Photosmart 2710 All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
