Question about Garden
I have a problem with my homelite ut-20046. It
I have a problem with my homelite ut-20046. It will only run on half choke, and even then accelerates poorly. Will not run at all with choke off. Any ideas?
    Problem Solver:
  • 18 Answers
Run some combustion chamber cleaner (not carb cleaner) through the carb with the air filter off.
Your main jet is partially clogged and it needs a richer air / fuel ratio to run - hence, why the choke needs to be all or partially on.
Hope this helps!
Rob
Posted on Sep 27, 2009
My Homelite chainsaw UT 10522B wants to start over revving on rpm's after it warms up.
that is usually telling you it has an air leak ............running lean
Sep 21, 2017 | Homelite Garden
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
It won't run prorerly
I had the same problem. I took it to the dumpster and used my old echo that I purchased in 1986. The Homelite was 2 years old. My sugesstion is to dump it.
Apr 06, 2010 | Homelite Mighty Lite Lawn Trimmer
My Homelite 26b will run at full choke but will not run at half choke or in the run position. I looked at carb and all gaskets. everything looks good.
make sure your fuel mixture is correct also check t your air cleaner it will not run right without it or if it extremly dirty
Oct 25, 2009 | Homelite Consumer Products MightyLite...
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
287 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
