Question about Texas Instruments TI-84 Plus Calculator
Screen frozen on ln( won't clear or accept any other buttons.
  • mrdeters18 Oct 13, 2009
    Thanks, but the screen is still frozen :( i guess i'll just have to get a new one
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Try taking out the batteries, include the backup battery if you haven't already. Backup battery is located behind a little door with a screw right above the AAA batteries. Leave all out for a few hours before reassembling. Another problem might be that the backup battery may need to be replace. Hope this helps.
Posted on Oct 04, 2009
The screen is frozen and nothing is working, need help
Your answer depends on where it is frozen. If at the start up screen or accept screen then you will need to call Rand McNally Tech Support. If you can get to the main menu and the GPS is freezing when in use then there are several items to review to troubleshoot a freezing issue.
First reset the device.The reset button may be on the side or back of your device depending on the model number.This will clear any running processing on the device.
Inside vehicle location - Have you recently moved the device to another location inside the vehicle.A temporary loss of signal due to the device not having a clear view of the sky can cause it to freeze.
Power - are you using the Rand McNally provided charger and have the device plugged directly into the vehicle?If you are using a splitter please remove that.Plug the device directly into the vehicle and press the rest button and see if that resolves the issue.Have you noticed if the charge indicator is always on?Does it flash?
Updates - have you updated your device recently?Updates are imperative to keep your device current with the most recent software.Have you seen any error messages on the screen?
Vehicle location - Experiencing severe weather?Traveling through a lot of rolling hills?Does it happen in the same area all the time?
If you continue to experience freezing of your device and have checked all of the above, please call technical support.A representative will perform a more in depth diagnostics.
Technical Support is available:
Monday - Friday
7am - 6pm (CST)
1-877-446-4863
TNDSupport@RandMcNally.com
Feb 23, 2015 | Rand Mcnally Intelliroute TND-520 LM Truck...
Screen has frozen Casio qt 6600
flag clear the till, and try again,
if it is a long report the till will stop and then start
flag clear power off the till on the side
hold the button down at the front
power on the till
press the ok button
then after 30 sec to 3 min
press yes
Feb 09, 2013 | Casio QT-6600 Cash Register Touchscreen...
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
My volume up on the Harmony 880 won't work. I've heard that one person did take it apart to clean the contacts, but that didn't solve the issue. Any suggestions? I don't even care if I...
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Aug 14, 2011 | Logitech Harmony 880 LCD Remote Control
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
My ipod has doubble screen wont accept my
hold menu and center button at the same time for ten seconds or until apple logo shows
Aug 29, 2009 | Audio Players & Recorders
Frozen iPod
move the lock button back and forth then hold the center and menu button at the same time for seven seconds. =)
Oct 23, 2008 | Apple iPod nano
Texas Instruments TI-84 Plus Calculator Logo
399 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
