Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
I have a Eureka Altima and not sure how to change the belt?
  • 8,197 Answers
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Posted on Sep 27, 2009
How to change belt in eureka altima vacuum
Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Dec 31, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
Replace a broken belt
Nov 15, 2009 | Vacuums
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Just need to know how to change the belt on my vacuum cleaner
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Nov 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
222 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
