Question about Norelco Health & Beauty
Replace SANYO N-700AAC batteries in Norelco 5865XL Shaver
Steps to replace SANYO N-700AAC batteries in Norelco 5865XL shaver. I have removed two plastic retainers for batteries but need to know how to release metal terminals of batteries from slots in mounting board.
  • 91 Answers
SOURCE: replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Hope it helps you.
Posted on Jan 07, 2009
SOURCE: How to replace batteries in Norelco 6826 XL
Amazon has a number of reviews that tell how to do this. See
http://www.amazon.com/Shaver-Battery-Norelco-models-others/product-reviews/B000FP63M4/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Posted on Mar 25, 2009
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
  • 1610 Answers
SOURCE: I have a norelco arcitec 1050 shaver. I can't
See link below for user manual. Everything you need to know is in the manual.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
Posted on Feb 22, 2010
Testimonial: "thanks for the response to my question. the information that was given helped tremendously. "
EwingElect
  • 276 Answers
SOURCE: Norelco 5825XL Replacement Blades
HQ5 is not compatible with HQ55. I've checked the Service Manual and HQ5 is the correct part. It's got to do with the driving mechanism for the head.
Posted on May 18, 2010
Shaver head replacement for norelco 5865xl
Philips norelco HQ5 replacement heads for men norelco 5865xl replacement parts refills electric shaver.
norelco 5865xl replacement heads
Dec 10, 2012 | Norelco 5865 XL Electric Shaver
How do you open the case to replace the batteries? Do the batteries have to be soldered?
On model 5865XL, remove the two screws on the back to remove the back cover. You have to slide up the trimmer to access one of the screws.
The batteries are soldered in. You will find the correct batteries at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 29, 2011 | Norelco 5865 XL Electric Shaver
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
Where can I find a replacement head for 5865xl? The ones I find in Walmart doesn't have this #on the box. Thank you for your help. Kellye Foss
Stores such as Walmart only offer a few of the many varieties of Norelco replaement heads. You will find the correct replacements for model 5865XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq5-reflex-action-replacement-heads-p-246.html
Dec 04, 2010 | Norelco 5865 XL Electric Shaver
Batteries dead how do you replace them?
For model 5865XL, you will find batteries for your shaver at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you first need to remove the back cover by removing the two screws on the back. One of theese screws is accessed by pushing up the trimmer. Once back is removed, you need to remove the two white plastic support pieces to properly access the batteries. You can lift out the circuit board and unsolder the old batteries but it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If this is not something you can do yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Aug 22, 2010 | Norelco 5865 XL Electric Shaver
Norelco 5865XL: Suddenly the blade heads are making excessive
It sounds like one of the heads is damaged. You will need to replace it. These come in sets of 3 combs and 3 cutters.
Jun 15, 2010 | Norelco 5865 XL Electric Shaver
How to replace Battery
You need to have a special Torx screwdriver to undo the screws.
You will also need a soldering iron, as the batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
You could obtain batteries from your local Philips Service Center (refer to www.philips.com) or check your Yellow pages for Battery Suppliers.
Apr 07, 2009 | Norelco Cool Skin 7775X Electric Shaver
Health & Beauty Logo
193 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
