Question about Kitchen Appliances - Others
Pizzelle maid 400 thermostat broken
I have a 1950's era Vitantonio Pizzelle Maid model 400. The thermostat is not working. At first it was heating and not shutting off. I tried to adjust the thermostat but now it turns off after 3 minutes but never comes back on when I try to cook a pizzelle. I need info on how to correctly adjust the thermostat or info on where I can get a new one.
freetek
  • 5568 Answers
SOURCE: Pizzelle maker 208 won't heat up.
Most appliances that work with heat, are equipped with a thermal fuse so if the thermostat fails, the fuse opens and prevents a fire. It is basically a good idea since all of our junk now comes from China and half of it is poorly designed and unreliable.
These fuses are normally not user replaceable since they are crimped or welded into series with one side of the AC line. And, they are tough as hens' teeth to find anyhow.
A year ago, I had three coffeemakers of the same model die in as many days. I took a refund.
The Toastmaster toaster we have, bought because of the name and appearance, is the absolute worst toaster we have ever owned. It regularly leaves one side of each slice burned, the other too light. I'm afraid the name means nothing anymore.
Posted on Dec 22, 2008
SOURCE: we have a Lektro Maid electric skillet that came
Miracle Maid and West Bend are both out of business. I just called and talked with Regal Ware who take calls about the cookware--1-262-626-8623. They cannot fix the problem because the terminals have a short and there are no longer any parts available! It is the BEST electric skillet ever!!
Posted on Mar 01, 2010
award462
  • 395 Answers
SOURCE: need instruction manual
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
  • 440 Answers
SOURCE: can't find main fuse box to change maid fuse...
Hi
It is attached to the starter solenoid under the side panel
Ride Safe
Bike-Doc
Posted on Jul 07, 2010
janalyn_glov
  • 58 Answers
SOURCE: broken leg on Villaware pizzelle maker
You might try putting a screw of about the length of the original leg into the underside of the casing (drill it a little with a power-drill or a Dremel, then carefully insert the screw with a handheld screwdriver, testing it at intervals to make sure it's the length of the leg,) and then cover the screw in some Sugru. www.sugru.com should be able to sell you a few packets of the stuff; it's heat-resistant, very strong, and I've used it in several kitchen-gadget fixes.
Posted on Aug 30, 2012
I have a pizzelle maker when do I know the right time to open & pour batter and when it is ready to be removed without burning
Some irons have one light that indicates that the heating element is on. I think that the Saulton iron has two lights. One light indicates that the iron is plugged in. The second light indicates that the heating element is on. You should wait until the second light goes off before trying to bake the first pizzelle. The second light will turn on and off as the thermostat regulates the heat. The cooking time depends on the pizzelle iron that you use. A good iron can bake a pizzelle in 30 seconds. The Salton iron WM8PZL takes up to 90 seconds for each cycle. Check the pizzelles after 30 seconds. The first pizzelles are seldom good. Experiment with the baking times to get the baking time right. After that keep up a steady pace to produce consistent results.
Early pizzelle irons were heated over open fires and made good pizzelles so with some practice you will be able to make pizzelles too.
Link to Recipe http://allrecipes.com/recipe/pizzelles-iii/
Jul 19, 2014 | Salton Pizzelle MasterWM-6Non Stick...
Lost pizzelle recipe from toastmaster please help .
Pizzelles were made before toastmaster ever existed and there is very little difference in pizzelle recipes.
Try this link.
Pizzelle Recipe Top Viewed Italian Cookie Recipe
Or this.
How to Make Homemade Italian Pizzelle Cookies
Dec 24, 2013 | Toastmaster Kitchen Appliances - Others
I lost my recipe booklet for my Berarducci "Dolce" pizzelle iron. Can you find one online for me?
There are 8 recipes in the manual available here: fantes.com/manuals/dolce-pizzelle-manual.pdf . Note: you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Dec 02, 2012 | VillaWare Electric Prego Pizzelle Baker...
Broken leg on Villaware pizzelle maker
Aug 29, 2012 | VillaWare 3600 Prego Pizzelle Baker
Where do I find this perticular make and model? I need 2 or 3 of 'em
You are out of luck as this is an old problem the season is long past.
I am fairly shure that Toastmaster no longer makes this Pizzelle iron. A better solution is an American made Pizzelle Iron by C.Palmer
Built like a tank and will probably outlast you. I wouldn't buy a non stick appliance from anyone as the coating is easily damaged.
http://www.cpalmermfg.com/products/Pizzelle-Maker.html
Oct 31, 2011 | Toastmaster 208 Pizelle Maker Waffle Maker
Manual for Toastmaster Pizzelle maker Model 208
what is the part # for the 208 pizzelle Thermal Control Module, and where can I purchase one?
Oct 01, 2011 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
260 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
