Question about Dryers
DRYER KEEPS OVERHEATING AND SHUTTING OFF MAYTAG SDG305DAWN.
  • Dryers Master
  • 8,404 Answers
Have you checked yout exhaust? It must be clear and clean. If it is a plastic hose, you should consider replacing with with a flexible metal hose. Dont forget the part outside.
You should pull the machine away from the wall, remove the hose and turn the machine on. Use the AIR setting. You should experience a strong flow of air. If not, there may be a clog between the exhaust port and your lint filter.
There is the possibility your machine is clogged between the fan and the drum. If you open this little space, remember the parts you find inside are powerful yet fragile
If you do have strong air at this point, reattach the hose. Go to the other end of your hose and repeat the experiment. Look into the hose - if possible, run something though it to assure it is clear and clean. If you get good flow there, inspect the device that takes your exhaust to the out of doors. If that device is clean and clear, it may be time to call a pro to look at your machine for malfunction.
I hope this helps you.
a
Posted on Sep 27, 2009
Testimonial: "It was lint build-up ,but not in the exhaust. The sensor just after the flame, heat on it's way back up into the dryer is sensed by 2 sensors, THANKS"
    President:
  • 1,922 Answers
Your hi-limit that shuts off power to element is more than likely bad
Posted on Oct 02, 2009
  • 334 Answers
The number one cause of overheating is improper air flow. That is usually due to a clogged or partially clogged exhaust vent. Check the outlet, the inlet at the dryer, and the pipe itself for lint, birds nests, kinks, collapses etc. Check the lint filter and filter compartment thoroughly.
It looks like Maytag LSE7806GGE dryer overheat thermal switch shutdown the motor. The motor is new. The vent looks good, plenty of airflow as well. What can be cause of this?
Lots of things.
Here are a few.
If the belt drives the drum, and the drum is not turning freely, perhaps it is loading the motor with too much resistance and the motor is overheating and shutting off.
If there is a bad ground wire anywhere in the system., perhaps the motor is not being grounded properly, and is having an electrical "melt down".
If the dryer is overheating because of lint accumulation inside the pipes of the dryer, perhaps the extra heat is shutting the motor down.
If the dryer is overloaded with clothes or whatever, perhaps the pull is too much for the motor and it overheats.
God bless your efforts.
Oct 31, 2016 | Maytag Dryers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Thermal limiter maytag bravos dryer
a thermal limiter is a safety switch designed to keep a dryer from overheating, by either shutting off the heating element or the dryer itself if activated. They don't normally need replacing (unless you know your dryer overheated and activated it). If you have no heat in your dryer, chances are you have a bad heating element--the most common dryer problem
Jan 01, 2013 | GE DSXH47EGWW Electric Dryer
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
My maytag duet electric dryer is heating, all controls seem fine, we cleaned out the lint traps, checked the hose and blew out vent as well. The dryer keeps shutting off early before clothes are dry. They...
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes.
As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time.
If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Dec 10, 2010 | Dryers
Maytag electric dryer keeps shutting off.Dryer gets hot. Repairman replaced the motor but still having the same problem.Could it be a sensor?
Generally if the motor shuts off it is because of the overprotector on the motor opening up to save the motor.When the motor cools down the overload will close and the motor will work again.
If the unit is getting so warm the motor is shutting off check to make sure the rollers are working properly and moving freely.
Sep 15, 2009 | Dryers
Maytag dryer quit running
your motor could be going bad. after running for several loads the dryer motor may be overheating and shutting down. wait for a while and if it restarts, replace the motor
Mar 30, 2009 | Dryers
Maytag dryer
if its completly shutting down aftger runnig for a bit, and sounds a little rough upon starting, sounds as if you may have a bad motor, its overheating( not allowing you to restart untill it cools off anyway.
Oct 19, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
260 people viewed this question
Top Dryers Experts
